... I just did a timinng belt (first) then i installed set of 2.8 intake cams... put the motor back together. Started & it idled and ran like crap... eventually it even stalls & dies..( only getting -12 to -14hg Vacuum as well)... I realize theres 1 million things this could be... so process of elimination... I started with main timing .... rechecked with CAM bar and it was off ... I identified it as a bad tensioner out the box... replaced & re timed
... started car and got my Vac back... -18hg.
Car idles ok... but then fluctuates dips & dies
Fuel pressure steady 51psi @ Idle. Measured just before fuel rail
Idles much better and constantly with MAF disconnected (open loop)
My concern before hunting down other causes ...
I want to eliminate the Timing concerns ...whether its the Main timing deviated again (which I doubt at this point)... or 2.8 cam shaft install... (trying to align them and set TDC relative to the Exhaust cam is no fun) but I believe I have them set as reasonable as can be expected.
All that to ask this..
BLOCK 93 in VCDS (Cam Timing Correction Factor Bank1 & Bank2)
Factory Spec is 0-4
...i'm getting 1-2 correction factor on Both Banks
With a Brand New Timing Belt & Tensioner and properly installed cams... is CFs of 1-2 normal?
Should I look elsewhere for my issues?
Thanks guys for any information
Sent from my SM-N950U using Tapatalk
