Results 1 to 7 of 7
    May 03 2018
    Florida
    A3 window issues
    I'm currently having issues with the drivers door window controls. I can't control any of the windows from the drivers door and I think the child lock is stuck because I can't roll the back windows down at all either even from the back controls. The only window that works is the passengers door when being controlled by the passengers door. The controls still light up at night so I assume there is power getting to it. When I roll the windows down using the key it works fine but I'm even having an issue getting the drivers window to roll all the way up now using the key, it's only rolling up like a quarter of the way. Ugh. Any thoughts??
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    Try this at every window individually and at driver’s panel if it doesnt work then; hold the button up for 5 seconds. It resets the module.
    Instagram: TonyConQuattro
    May 03 2018
    Florida
    Try what exactly?
    Feb 21 2016
    Holding the window buttons up for the 5 seconds.
    May 03 2018
    Florida
    I just tried that and nothing. What's weird is that the back windows are now working when controlled from the back doors and I was just able to roll the passenger window up from the drivers control but it won't go down (from the drivers door). Ugh.
    May 03 2018
    Florida
    I just noticed that I can roll UP both front and back passenger windows from the drivers control but I can't roll them down. I can't roll up or down either the front or back drivers side from drivers control. So weird.
    May 03 2018
    Florida
    I ended up taking my door apart to see if I could see what was happening. I was actually prepping it to pull the switches out as I ordered new switch off of eBay. Anyways I found out that the pad with the actual buttons (underneath the switches) had come loos and so the switches weren't actually touching the buttons. I was able to push the back part back up and lock it in place but the front part wouldn't snap in for some reason. It still kept coming loose. I ended up just putting a dab of super glue to keep it in place so that the switches would make contact when pressed down. Should be good to go as long as that glue sticks.
