Results 1 to 40 of 64
    Veteran Member Three Rings Delasangre4231's Avatar
    Nov 22 2012
    Portland, Oregon
    ESC, Sport Diff, and TPMS Faults
    I have been searching and can not find this combination of faults. All my local shops open Monday. I can't find my code reader. I was cruising 60MPH on the freeway and suddenly cruise shut off and I got "Stability System Fault, Sport Diff Fault, and TPMS Fault". The car drove fine the rest of the way home but cruise doesn't work. All the tire pressures are fine.
    -2016 VW GTI Autobahn Performance pack DSG
    Michelin Pilot Super Sports, APR Carbon Fiber Intake, APR Stage 1 ECU tune
    -2003 VW Golf 2.0 5-speed SOLD
    -2013 Audi RS5 Phantom Black Pearl SOLD
    Michelin Pilot Sport 4S, ECS Brake lines with Motul RBF600, ECS X-Pipe, Leyo Motorsports paddle extensions
    -2003 Audi A4 Avant, 6MT, 3.0 V6 SOLD
    B6 S4 front brakes, JHM stainless brake lines, Straight Pipe - http://youtu.be/7zsiB7rT1fo
    Aug 28 2015
    Illinois
    Had that happen and took it to the dealership. It was a bad module/sensor, they replaced the sensor. Drove off and the car threw all 3 errors again. Drove back and they replaced the sensor and repaired the electrical short that caused the problem. Problem solved.
    Prism Silver RS5
    Nov 22 2012
    Portland, Oregon
    Took it to my independent Audi shop this morning and there was a handful of random unrelated sensor issues, but the big one was over voltage, they said it looks like the alternator is over charging and therefore throwing off voltages at all these sensors. So I left it at the shop and I'm awaiting their call to say what they find or do.
    Senior Member Two Rings midam96's Avatar
    Dec 20 2012
    dallas,tx.
    Mine is doing same exact thing ....
    Nov 22 2012
    Portland, Oregon
    So my independent German specialty shop said over-voltage issue, Carmax since it was under warranty still looked at it and said it was a low voltage code probably because I don't drive it (Which I do, 40+ miles daily). So they cleared them, charged it and test drove it and they said its fine. So far the lights arent back but I have an appointment at the independent shop to do a charging system test because I don't believe Carmax.
    Dec 20 2012
    dallas,tx.
    Blocking my reply? Is forum blocking me ? Add CEL for flashing dash icons
    Dec 20 2012
    dallas,tx.
    Had written 2 previous longer posts both were timed out or not allowed
    Dec 20 2012
    dallas,tx.
    Agree with your wanting an honest answer to issue. Audi Service is tremendous weak spot at most (not every) dealership. I feel like today’s Income for next quarter earnings release.
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by midam96 View Post
    Who's blocking your reply?
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    There's usually limitations set up in the back end to keep people from spamming pages. Unfortunately, that means some lengthy posts that are legitimate have to be split up. I'd suggest writing it out in word, and just copy/paste a section at a time (if you actually want to take the time to type it out again, of course).
    We had to put limitations on a forum I managed because we had several troll users that would put heaps of invisible font in posts above a single sentence, all just to make people waste time scrolling.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Dec 20 2012
    dallas,tx.
    That makes sense, thank you.
    Brake light switch?
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    Quote Originally Posted by PedroRS5 View Post
    Any details on what sensor was responsible?
    I'm getting the same faults - ESC, rear diff, TPMS, and several other codes pulled on scan. I'm thinking possible battery, but really don't want to start playing parts darts.
    thanks
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Nov 22 2012
    Portland, Oregon
    Below are the codes I pulled the 2nd time around, my local Audi dealership looked at them, saw the MAP sensor code and tested the sensor with a multi-meter and found it to be bad. Since they replaced the MAP the car has been trouble and code free for the last 2 months. Interesting to note that my independent shop didn't think it was the MAP even with the code because they had never seen a MAP fail and NOT make the car run like snot.
    01 Engine
    Trouble codes:
    U111300 - Function limitation due to received malfunction value
    static
    P010600 - Manifold Abs.Pressure or Bar.Pressure Range/Performance
    static
    02 Transmission
    Trouble codes:
    U040100 - Invalid Data Received From ECM/PCM "A"
    static
    03 Brakes
    Trouble codes:
    01314 - Engine control module (ECM) Please read DTC
    static
    01324 - All wheel drive control module Please read DTC
    static
    08 Air Conditioning
    Trouble codes:
    00713 - Left air flap motor for center vents Lower limit not reached
    static
    00714 - Right air flap motor for center vents Upper limit exceeded
    static
    13 Adaptive Cruise Control
    Trouble codes:
    static
    01316 - Brake control module Please read DTC
    static
    22 All Wheel Control
    Trouble codes:
    U101700 - ABS brake control module Read out DTC
    static
    53 Parking Brake
    Trouble codes:
    static
    Mar 21 2010
    Charlotte-ish
    Wow, that's crazy that the MAP would trigger the other faults. Your additional codes look eerily similar to mine (except I'm using Carista) and P0106 is the first one on the list.
    Makes some sense though as I just replaced both PCV valves 2 weeks ago. At least gives me a direction to troubleshoot. Probably need a battery anyway as I am also getting the quiescent current and energy management active codes.
    Thanks for the reply.
    BUCK
    Nov 22 2012
    Portland, Oregon
    You are welcome, and good luck!
    They way I understand it all the modules throw an ECM code because there was an engine code and everything else went into a sortof limp mode, even though it didn't limit power.
    Mar 21 2010
    Charlotte-ish
    Will be in Portland first part of September. If this turns our to be the culprit, will buy you an adult beverage!
    BUCK
    Mar 21 2010
    Charlotte-ish
    So had some errands to run yesterday, faults were cleared and returned 2 or 3 times in span of about an hour. Found a Bosch MAP sensor at Advance Auto for $40 (Audi gets $99 for same).
    Replaced last night, ran the bejesus out of it last night and on the drive in this morning. So far so good....fingers crossed.
    Seems very coincidental that this started the day after replacing both PCV valves. There was some oil on on the old sensor, so curious if contamination led to failure.
    Looks like a I owe Delasangre a drink
    BUCK
    Nov 22 2012
    Portland, Oregon
    Fingers crossed that was it for you. My car lit up like a Christmas Tree last night, codes point to bad Adaptive Steering Module. Steering wheel even cocked to the right to drive straight. Super weird. I got home and saved the log then cleared the codes after cycling the ignition, drove down to the convenience store and it didn't come back. Praying it was a fluke but I have a bad feeling about this...
    Mar 21 2010
    Charlotte-ish
    Well hell! Faults are back !!*@#&% Still have MAP sensor code that looks to be the initiating event. Possibly the wiring connector? It seems to be a little loose when connected, not the usual snug fit.
    I hate chasing gremlins.
    BUCK
    Nov 22 2012
    Portland, Oregon
    Dang. I was chasing a random Gremlin like that on my last Audi and nobody could find it so I sold it and ran. Since the last one was covered in oil I'd be curious to pull it and see if it's covered again.
    Dec 20 2012
    dallas,tx.
    How did you end up ? My 2013 is doing same thing. They changed my map sensor but lights came back car runs fine sans adaptive cc and abs systems. I’ve had two smaller town Audi dealers look at it to no avail. I have brought it back to Dallas has appointment Monday with experienced Audi guy hopefully get it sorted. Very disconcerting and a little disappointed in Audi’s ability to service cars they sell at least in Central Illinois ( laughing) ok it is John Deere territory. If you’d please tell me how your car was fixed it might help us sort mine. Thanks and Happy Holidays.,Roger
    Nov 22 2012
    Portland, Oregon
    Mine was the map sensor. That solved this problem but my RS5 has been a nightmare. One problem after the other. Camshaft adjustment solenoid, and I'm like 10 hours of diagnosing deep into this stupid steering problem and my Audi dealership can't make heads or tails of it. I'm getting ready to sell this POS.
    Veteran Member Three Rings S4fever's Avatar
    Dec 17 2008
    Had a similar issue with my B8, ECU wouldn't communicate with VCDS and the radiator fan was activated at high speed. Battery would die within 10 minutes trying to scan for codes. One afternoon in December I went to start the car and CEL popped up and car made a loud "backfire" upon cold start... Shortly after it disappeared. Drove the car for 10 minutes and came back home and went to start the car again and that's when I got all the same error codes except I had parking brake malfunction along with EPC light and few other fault codes... Not to mention the car wouldn't start.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Quote Originally Posted by mcbuck View Post
    thanks
    Did you ever figure this out mcbuck? Did you have a look at your engine mounts?
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Dec 20 2012
    dallas,tx.
    Aside from this issue car has been fine with exception of mistaken service on sport differential but Shop readily accepted their error. I had intended to hold car as last of an era but with the gremlins showing up in electrical I’ve removed the Audi rings looking for Jaguar badge stripped back temp and fuel gauge for Smith Electric logo haven’t found any but damn sure seems to b acting English which would be no bueno. Car goes to yet another Audi shop Monday I’ll report back. So far I’m a map sensor, new battery, into fixing it to still be no closer. As car sits upon start Abs chime,tpms, sport differential lights activate in that sequence. More film at 11
    Dec 20 2012
    dallas,tx.
    You would think Audi has knowledge of this they have people reading this forum.
    Dec 20 2012
    dallas,tx.
    Next step..., changed ECU weÂ’ll see if that solves the throwing code issue. Not particularly happy at changing an ECU but I suppose after 56,000 miles something came unattached. See if it still throws codes over next few days.
    Active Member Two Rings SoCal_OOOO's Avatar
    Apr 10 2016
    Southern California
    I had the exact same thing happen to my 2013 RS5. Twice. The second time the dealer reflashed something and it’s been about a year since with no issues. At one point they blamed the tires... I don’t think they know what it is but I think we are all coming to the conclusion it’s electrical and not a hardware fault with the sport diff, which is nice at least!
    At what point and how does Audi realize this is a common issue and proactively try’s to actually fix it?
    - - - Updated - - -
    At what point and how does Audi realize this is a common issue and proactively try’s to actually fix it???
    Dec 20 2012
    dallas,tx.
    Final resolution
    My final resolution was to replace ECU that seems to have resolved the throwing code problem. ECU had broken soldering points holding circuit boards. I’m not sure I would extrapolate that to apply to all ECU’s for the RS5 I’m guessing it’s a Bosch Unit so Audi just receives shipments of them.
    Quote Originally Posted by SoCal_OOOO View Post
    - - - Updated - - -
    Dec 20 2012
    dallas,tx.
    Car is throwing codes again changing the ECU worked for about a week. So now I’m out a map sensor purchase and install, change the ECU plus the install and apparently no closer to a solution. Car is back at Audi Dealer and they appear stumped. Very disconcerting to have them tell you “ well we just don’t know “
    Nov 22 2012
    Portland, Oregon
    And that's why I just sold my RS5 and walked away... I hope they figure it out but from everything I've had to fix it seems these are electrical gremlin cars.
    Jun 24 2017
    San Antonio, TX
    Do you have adaptive cruise midam96? How bout you Delasangre? Either car been in an accident? Curious if the adaptive cruise is not calibrated correctly or the sensor is damaged.
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by Ape Factory View Post
    Mine did but it was fine, they checked the calibration and it was ok. They said my car needed a steering rack but they couldn't guarantee that was the cause of this CEL problem
    Dec 20 2012
    dallas,tx.
    Yes to Adaptive CC, no to any accidents
    The warning lights in order of appearance abs,tpms, sport differential
    Dec 20 2012
    dallas,tx.
    I’m about fed up as well if Audi of America doesn’t have some information to help solve the issues. I’m reaching out to them Monday. The people who have My rs5 n Chicago have been excellent to work with but nevertheless they are scratching their heads and have no real plan other than change one thing at time.
    Nov 22 2012
    Portland, Oregon
    Ya that's the point I got to but it wasn't under warranty so I was paying $159 an hour for them to say they don't have a clue
    Established Member Two Rings jason bouchard's Avatar
    Jun 08 2008
    fook, this is a scary thread to read, I just bout a 2014 S5 with 51k miles . . .
    2014 S5 6-Speed -dual pulley 187/57.5 ( PR 3.25) | Eurodyne Maestro tune| AWE coldfront HX | AWE coldfront upgraded reservoir | CF ECS tuning Intake pipe with K&N filter | JHM racepipes | ECS 2.5in Valved exhaust | SPEC stage 3+ clutch | Clutchmasters 23lbs AM singlemass flywheel | P3 Gauge w/ trackpack + analog boost sensor | 1 stage colder NGK plugs (BKR9EIX)
    2001 Audi TT 225Q (sold)
    Jun 24 2017
    San Antonio, TX
    I would maybe try to have them contact a U.S. National-level master tech who specializes in RS cars. I know they're out there. If you have the adaptive cruise, you have the dynamic steering rack. Twice as complicated as the regular steering rack.
    Jul 21 2004
    South Florida
    Take a multimeter to the battery. Most of those modukes require battery voltage checks and when batteries start to go bad they trip multiple module trouble codes. Itll look like a cristmas tree. Check battery voltage.
    2018 Audi S5
    Gone-
