Originally Posted by
gk1
The factory 20Nm spec for the pan drain plug is because the oil pan is aluminum and the bolt is steel.
I was going to comment on this, so perfect timing. He he. Where the plug sits is STEEL. That's the 'weird' sandwich I mentioned. The magnetic plug attaches with ferocity to that area, but not to the rest of the pan. FYI. Porsche is aluminum, but beefier. The oilpan in a much thinner aluminum sheetmetal, rather than a casting. Anyway, the factory plug had at least 40 ft/lbs, so decided to put 25, which is the most common spec. Porsche uses 37 ft/lbs on aluminum plug and pan, which is ridiculously high IMO. Never owned a car with more than 25 ft/lbs until the Porsche. Hopefully the threads will hold over time on that ECS plug, but if I don't see much debris accumulated on the magnet next oil change, might revert back to the stock steel plug. Otherwise will try to use it until it fails, to see how beefy it is. The fit is fine, but since the plug is aluminum and the threads steel, it needs space to expand, hence being 'wobblier' than the OEM steel plug (by necessity). By the way, don't know what Audi used on my pan before (maybe during engine testing) that marked the drain plug's area much wider than the factory crush washer. After fishing the factory plug and washer from the oil container, turns out it's basically the same size as the ECS. The washer also had only about 1mm of contact after the 'serrated' stamping, so barely sealing, just like the ECS. That's why I decided on 25. With 15, or even 20, it wasn't going to crush enough to reach that flat area IMO, so went with 25. Won't know if it leaks, but really doubt it. Cleaned all the underpanels perfectly, so next time I'll know if anything leaked. The oil filter is basically impossible to install wrong; don't understand what happened with those turbo failures that said improper oil filter installation. Once you sit the filter on the cap, which 'clicks' into place with a loud noise. You really have to be a rookie not to sit it properly. After that, it's impossible to install wrong. My car will need about 9-1/2 qts to full after draining it overnight. Didn't leave the container, and even though it was barely dripping, found a lake of oil in the morning. Put about 9-1/4 qts, and it's still about 3/4 to full, but will top it off after coming from my long trip, once it's cold. Won't have time tomorrow. Hope to have luck, and suffer less damage than usual. Have a good one folks.
