Results 1 to 3 of 3
    Established Member Two Rings iowa_gts's Avatar
    Feb 23 2011
    cedar rapids ia
    New clutch not working properly
    About 3 weeks ago had my stage 3 eurocode and LWFW installed with SS clutch line c the car felt great till about 4 days ago. While still in the break in period just normal in town driving I would have to push the clutch to the floor for it to disengage from gear to gear , and if I pushed the pedal down like normal it would feel like I didn’t even push the pedal down at all cause it was hard to get into gear and out of gear.
    I have the extended slave for the push the start fail. Thought it needed to bleed the system but that didn’t work , wondering if anyone has had a problem similar ? It is currently back at the shop
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Pressure plate bolts backed out?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    ^^ That's a good starting point, use red thread locker not blue. Also check TOB alignment and for a leaking clutch master.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
