Results 1 to 13 of 13
    Established Member Two Rings boropawel22's Avatar
    Oct 20 2014
    Fort Bragg
    Brake and rotors replacement
    Hey guys, I need help with suggestions on replacing my brakes and rotors. Audi dealer quoted me mad money for OEM parts but I rather buy the parts myself and take it to the mechanic. Can you suggest a kit or brand, something mid price range, no more than $500 for front and rear. Thanks guys
    Established Member Two Rings ValidatedS4's Avatar
    Oct 08 2017
    2013 S4 6MT
    Boston, MA
    Akebono pads and Zimmerman or Meyle rotors. I ordered from rockauto. Very happy.
    Low brake dust and I like the “less bite” compared to the oem metallic pads. Makes it easier in stop and go traffic and parking ect..
    Established Member Two Rings EvohuntinS3's Avatar
    May 22 2015
    Northern VA
    I actually used ECS slotted rotors and EBC red pads. Very pleased, performing very well.
    15' S4 Mythos Black Metallic
    Mar 28 2016
    Quote Originally Posted by ValidatedS4 View Post
    Agredd with this recommendation.
    Senior Member Two Rings steampunkjunker's Avatar
    Jun 21 2017
    NorCal
    What are your goals for braking? Low cost, low dust, low noise, cold braking, high performance?
    For $550 you’d have to go with very affordable rotors which is fine and then put the rest of your budget on the appropriate pads for your application. Also don’t forget a good bleed.
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15, H&R 10/12mm wheel spacers
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: GIAC - Stage 2, Redline oil
    • Coming soon: GIAC - TCU, Bilstein B12 Pro-Kit
    Aug 05 2016
    San Antonio, TX
    What's your miles at that you need new rotors and brake pads?
    2014 Audi S4 | Glacier White | Sports Diff
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Zimmerman rotors with OEM supplier pads via Europa parts. Right around your $550 price point for parts. Use CRC Brake Quiet on the back of the pads and bed them properly.
    Sent from my SCH-I545 using Audizine mobile app
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Oct 20 2014
    Fort Bragg
    I got 55k and I drive very aggressive.
    I’m looking for performance over everything else.
    Aug 08 2016
    Oshkosh, WI
    I did slotted ECS rotors and Hawk pads. been great even in the salt infested midwest.
    2013 S4 monsoon gray. EPL DP (fluidampr 183). Milltek exhaust, rotiform wheels, KW variant 1 coilovers, PLM HE, 034 alu kruez, 034 motormounts, trans, diff mounts. solowerks rear swaybar, CR-15 brace, roc-euro intake, rs grille etc. And 2 Land Cruisers
    May 31 2014
    Alabama
    Slotted ECS rotors w/Stoptech (Link)
    Got them installed last week. Though there was initial heavy squeaking, everything has been great once I bedded the brakes.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    +1 me to this.
    Brake pads warning light came on around 32k miles. Dealer quoted me around $1k if I remember for brake service.
    Both from ECS
    Front Euro Ceramic Brake Pad Set Akebono = $106.95
    Zimmermann Front Brake Rotors - Pair (345x30)
    Featuring the 'Coat Z: Anti-corrosion' = $177.90
    Labor Cost from Indie shop = $158.00 Front brakes only.
    Total = $442.85
    Definitely felt the difference with the less bite when you step on the brakes compared to OEM pads but you get less brake dust and it's quiet. I am going for the same setup for the rears when the time comes to replace it.
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    What do you guys think about the product brakeperformance(dot)com puts out?
    http://brakeperformance.com/brake-ro...nc-coating.php
    I'll be needing an all new set by the end of the year.
    2013 S4 6MT mods:
    APR intake backpipe w/ modded stock airbox, AFE Air Filter, CTS 187mm crank, APR 57mm charger, APR HX, Stasis Catback, CR-15, 034 Stage 2+/034 Stage 1 CARB
    Senior Member Two Rings The Machine's Avatar
    Aug 08 2017
    Earth, TX
    Quote Originally Posted by BucDan View Post
    I literally just put new pads and rotors from brakeperformance on my wife's car Saturday. Granted it's not an S4, but I have no complaints about the quality of their parts and stopping is nice and quiet.
