Results 1 to 8 of 8
Thread: NJ Emissions
    Jul 20 2017
    Naples, FL
    NJ Emissions
    Hi guys!
    Im moving back to NJ after some time in FL. I was all set to go Stage 2 with my 8V A3 (bought the parts and everything) but then got the job in NJ.
    Will I pass emissions with APR Stage 2 With a CTS turbo catted downpipe?
    Thanks in advance for your help.
    Tyler
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Hey, welcome back home Tyler!
    As far as emissions go, unless things changed, freehold dmv is just in and out. Went with the mods listed below and didn't have a problem at all, so unless it's out of the way for you, then you're fine
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
    Feb 22 2017
    2017 BMW X1 (wife's)
    Burlington, NJ
    NJ Emissions
    What year is yours? I have stage 2 as well and my car is registered here. It fell under the new car rule and got a sticker 5 years after my model year so I’m good until 2021. I moved here last year from Alabama so the emissions stuff worries me as well.
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    In NJ, if you go to the DMV inspection stations, they plug in to the OBDII to scan for errors and they do visual check to ensure you have cats (no sniff test). As long as you have cats and no errors then you should be good to go. If your vehicle is less than 5 years old then no inspection needed until after the 5th year as stated above.
    IG: @puzoyAlex
    C6.5 A6 Avant Ibis White | KW V3's| H&R F+R Sways| XLR8 Dual Pulleys| EPL Stage 2 tune| S4Matty Ported SC+TB| APR CPS| JHM Downpipes| SkiGuard Roofbox|
    gone ---> B8.5 S4 Sepang Blue (6MT) |APR Stage 2+ UC|
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Quote Originally Posted by alexdell View Post
    You don't need an inspection if your car is less then 5 years old in NJ?
    Jul 29 2011
    Central NJ
    Quote Originally Posted by AUDIMAN33 View Post
    That’s correct! One of the benefits of moving to NJ from NY. Plus the inspection station only inspects emissions. You’re at the mercy of the cops when it comes to front window tint. I’ve been following that NY tint law thread
    IG: @puzoyAlex
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    If you are OBD2 compliant will O2s on you're fine!
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
    Jan 11 2014
    That's crazy, and cool. NY should do that. The NY tint law has fucked so manny people over.
