Hello,
Im trying to remove the fuel rail so i can replace the PCV valve (cracked and leaking coolant).
I removed the 5 screws and 2 nuts off the top, the fuel rail will wiggle a little but wont come up.
do i just need to use a lot of force to pull the injectors out too/ get the injectors out of the fuel rail..
any help needed.
thank you!
