Results 1 to 2 of 2
    Senior Member Three Rings on1wheel01's Avatar
    Mar 03 2012
    mooresville nc
    2006 a6 possible J518 issues ?? Or something else ?
    Hello all. Just picked up a used a6. Got it knowing had issues. To start I assume itís at least J518 module bad maybe more. Steering is locked , shifter is locked even if you release the shifter via button under ash tray the wheels donít move. Wonít start nor does it turn over. Also the key wonít come out once in unless you push in the small pin. Tried to wake up the car using vag com. But it wouldnít talk to it. Hold brakes, emergency flashers on , and held in high beam( now I was told maybe I needed to flicker the high beam every few seconds would this make a difference?). I figure either the module is completely shot or I have a bad fuse or relay. Any idea where I should start??
    Edit just found out my friends vag com cable only supports up to 2004. So thatís why it wouldnít connect. He just ordered the newer style so I will hope it wakes the car up
    Mar 03 2012
    mooresville nc
    I am happy to report my friends newer cable woke the car up. I was then able to hear it run and remove the module. I had a ton of error codes though.
    03 A4 Quattro stock for now mods to come
