Results 1 to 10 of 10
    May 02 2018
    Chicago
    S3 Front license bracket
    Dealer wants about $200 for the front plate bracket for my 2018 S3, knowing the dealer overcharges on just about everything do you guys know of any cheaper front license brackets you'd recommend?
    OEM or non-oem as long as it gets the job done.
    I was going to go the whole tow hitch route but due to reading a lot of people having problems with the parking sensor I think I'm just going to center it to avoid this problem.
    May 03 2018
    New York
    I have the platypus tow hook bracket ($90ish a couple years back). Great looks and quality if you need a front plate, but occasionally it does trip the sensors during parking, almost 100% of the time in the wet. I don't know if it's possible not to trip the sensors near the tow hook because the front two sensors are pretty close together, so the farther you get from one, the closer you get to the other.
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    I have my oem holder I no longer use if you were interested
    Sent from my SM-T350 using Audizine mobile app
    Established Member Two Rings Corners4kids's Avatar
    May 10 2016
    2019 Tiguan SEL Prem (wife)
    Centennial, CO
    My wife’s A6 uses the same holder our cars do. She had a truck with trailer hitch back into her. That’s the only thing it broke (less than 3mph). Found an identical to OEM version on amazon. About $15. Tons of choices. Way less than $200.
    May 02 2018
    Chicago
    Quote Originally Posted by ralphie_43 View Post
    Check your PM's sir!
    May 02 2018
    Chicago
    Quote Originally Posted by Corners4kids View Post
    Really? All I found on amazon were the tow hitch ones, care to post a link of the one your wife bought?
    May 02 2018
    Chicago
    Also can't find much online for S3 front license mount, is the S3 mount the same as the A3?
    May 10 2016
    Centennial, CO
    CPP Replacement Front License Plate Bracket AU1068107 for 2015-2016 Audi A3, S3 https://www.amazon.com/dp/B076VWT6CT..._pKn8Ab20280WT
    Looks like it’s $70 for our car. Some different cutouts and such. Still, hope is helps. Way less than $200. Amazon is great about returns too in case it’s not a perfect fit.
    May 02 2018
    Chicago
    That will also fit 2018's? Just want to make sure before I purchase...
    May 10 2016
    Centennial, CO
    Hmm. Sure about a 2017, but not the 18. Maybe call a local Audi dealer and ask if the 17 and 18 have the same part number? I doubt it’s different as it’s a pretty simple piece of plastic, but it’s an Audi so who knows for sure.
