Originally Posted by
s4sprint
Anyone else have these symptoms: During the first 1-2 minutes after a cold start the engine stumbles or hesitates during light acceleration? It was first noticed during the winter but seems to be getting more noticeable, even as the weather has warmed. I never noticed it before this winter. After two minutes the stumbling disappears and runs perfectly. The car is 2011 with 40k miles.
Do you have VCDS? Data logging might help find the problem.
One thing - worse scenario would be a cracked cylinder head. This can happen if you get in subfreezing weather and don't have enough antifreeze. The frozen water/coolant expands as it freezes and causes a small crack in the cylinder head above the water jacket.
What happens then is that when you start the engine water leaks through the open crackinto the cylinder causing a misfire. But, as the cylinder heats up, the heat expands the metal and the crack closes, sealing back up. Blown headgasket can do the same thing sometimes. If you haven't overheated, its probably just the s/c jacket leaking.
I hope its just the s/c water jacket. Easier, less expensive fix. Either way, you would be losing coolant and having to top off. Is that happening?
