sadly, my beloved B6 was hit by a (presumably) drunk driver who fled the scene, totaling my car. Impact was at the front passenger side, everything else was unharmed. Came across a deal I couldn't pass up on an RS4, so parting out what isn't getting migrated over.
Car is located in Austin, TX, and prefer a local sale for big items, but will ship at cost. I'll be editing this list and adding pictures as I pull items off / think of more things. Sold / damaged / not available parts listed at the end. Exterior is Denim Blue, interior is soul/black.
Google Photos album link: https://photos.app.goo.gl/vXqccSBTKmEYURp36
PM or text me at 512.981.6636 for quickest response
thanks,
Matt
- ABS module
- trunk latch cover (U-shaped)
- trunk interior release handle
- pass side fuel level sender
- driver side fuel level sender
- headlight switch, non-auto (ebay/non-OEM)
- headlight switch, auto (ebay/non-OEM)
- pushbutton toggle switch in headlight switch trim (use to mute radar detector)
- headlight switch trim (black, new)
- 02 CCM (-T)
- door cards (non-Bose)
- sunroof motor
- interior trim (lower B-pillars, kick panels, etc)
- Bosch 3.25" B5 S4 MAF (no housing)
** SOLD **
- RS4 door pulls (g.audi)
- JHM short shifter (B6 5-sp) (g.audi)
- JHM shift linkage (01A) ((g.audi)
- center dash vent (g.audi)
- steering column top cover (g.audi)
- RS4 pedals (w/dead pedal, selling as full set) (studiobmx)
- blue euro side mirror glass(studiobmx)
- 034 HFC (BerlinerB6)
- Billy Boat Stealth exhaust (w/4" slant tips) (BerlinerB6)
- 034 rear anti-sway bar (AU02DI)
- color A4 instrument cluster (swededa4)
- JHM test pipe
- flat door blade set (3/4 straight/true, denim blue)
- B7 S4 300mm rear brake setup (blue)
- Stoptech 355mm front BBK (blue w/audi sport logo, new rotors/pads, <1k) (local)
- B6 S4 Recaro seats (black nappa leather, non-heated, VG condition) (local)
- driver/passenger window switches (A4orce84)
- alternator (Bosch reman, <5k mi) (A4orce84)
- coolant tank (a4orce84)
- driver interior door handle (A4orce84)
- Blackberry A2DP BT Gateway (A4orce84)
- B7 steering module (for MFSW retrofit) (A4orce84)
- B7 clockspring/slip ring (for MFSW retrofit) (A4orce84)
- trunk struts (A4orce84)
- door seals (A4orce84)
- B7 siren alarm (1.8Turbo4me!)
- Sportec Mono 10 wheels (4 good, 18x8.5 ET32, condition 7/10) (local)
- Aero wipers and blades (myers)
- ECS black billet aluminum dipstick/tube (myers)
- updated fan control module 8E0-959-501-AG (myers)
- hood latch (w/o microswitch) (myers)
- custom air leather Euro shift knob w/boot (bran1on)
- 034 silicone block breather hose kit with billet PCV valve (fits AWM, AUG, AMB up to VIN 8E-3-040000)
- 630cc injectors
- b7 center console w/e-brake
- ER Competition FMIC (needs hot side pipe replaced)
- Forge 007 diverter valve (piston type, polished) (BA4IN775)
- HVAC (B7, no seat heaters) (jr82s4)
- RS4-style Votex/DTM sideskirts (front part of pass side cracked but repairable) (fsteve)
- power steering pump (OEM reman, ~10k miles) (A4orce84)
- 3.5" B6 S4 MAF (w/housing)
- Bosch 3 bar MAP sensor (quattro guy)
- 034 SAI block off plate (quattro guy)
- black visors, grab handles, map light assembly, etc (empyrestate)
- RNS-E (2nd gen, gloss trim, normal dials, reboots on occasion) (neo0211)
- upper radiator hose (A4orce84)
- IE intake cam + adjustable timing gear (itsmatt33)
- 03+ CCM (-BB) (for using B7 key fobs on '02 A4) (itsmatt33)
- trunk latch actuator (APC123)
- AFE dry-flow air filter (APC123)
- Aeromotive 340 fuel pump with basket etc - drop in replacement, wired and ready to go (trinitigger)
- large port AMB intake manifold w/nipple for FPR (trinitigger)
- starter (Bosch reman, <5k mi) (trinitigger)
- engine rain tray w/battery cover (local)
- Eibach ProStreet S coilovers (custom KW valved shocks, roughly equivalent to KW v2) (aago)
- GT2871R eliminator turbo (w/Frankenturbo manifold) (frogspit)
- built AWM head (g.audi)
- S4 rear bumper (recently painted, 1 small scuff on back) (local)
- stock tail lights (local)
- ECS skid plate (local)
- OEM RS4 air leather e-brake cover (7/10, light wear from contact with armrest) (rhfosu)
- AWM fuel rail w/FPR (Furly)
- shaved black powdercoated coolant hard pipe w/metal bleeder screw (itsmatt33)
- Zender trunk lip spoiler (recently painted) (B6_A4_Kid)
- spare 01A 1-piece center diff
- ECS Stage 2 RA4 clutch (B5 RS4 disc/pressure plate, ECS 240mm flywheel)
- washer tank / windshield nozzles
- 2.0l short block (PZ)
- black Alcantara/ultrasuede headliner, A/B/C/D pillars (jonan)
** NOT AVAILABLE and/or DAMAGED **
- front bumper
- headlights
- pass front fender
- hood
- airbox
- Porsche oil/coolant caps
- driver lock/unlock button
- driver trunk release button
- passenger door pulls / door handle trim
- carbon fiber interior trim
- rear diff mount
- emergency triangle
- emergency triangle holder
- SPC adjustable upper control arms
