Alright.. So for the last 6 months I've had a P0492 and P0491 codes on my B8 S4 (Secondary Air Injection - cold start).
So here is what has transpired:
I removed my supercharger to add an EPL pulley as well as change out (preventative) thermostat. I also added a Gen1.0 MercRacing Heat Exchanger during the process.
Upon first drive after reinstalling - I pulled a check engine light P0492 and P0491 for the SAI.
This was strange but I figured that during the install - I must have triggered something for the carbon buildup block flow and trigger the light.
So. I took the car to Audi for extended warranty cleaning of the SAI and they cleaned it under warranty. Picked the car up, CEL gone. 3 days later - it popped again.
So. I took it back. They took the car in again and the tech says the carbon/flow values are in spec. They spent the whole day on the phone with audi corporate tech and came back with this:
"Bad Combi Valve" - or EGR value. Quoted this not under warranty, $650 parts and labor.. Hmph.. Strange..
https://www.ecstuning.com/b-vemo-par...6e131101e~vmo/
There are left and right combi valves. But.. Now I'm suspicious AF.. Why? Because of the "binary" nature of this CEL. Car never pulled a CEL, then I pulled the blower for a mod and boom - CEL.. Did the EGR/Combi Valve go bad? Doubtful.
As of this morning - I am convinced (telling myself that) that I have a vacuum routing issue. This is where I need your help. I don't know the way the vacuum routing SHOULD be - but it's got to be that.
I created this thread a few months back with a bunch of pictures of my vacuum routing. Something must be wrong.. Can someone look at this thread (Audi Tech!?!?) and tell me where I am off?
https://www.audizine.com/forum/showt...ighlight=P0492
Also - after looking at this thread where the AZ'er had service work done and then pulled these codes and then found vacuuum lines weren't connected - I'm even more confident that this is the root of my error
I may have a cracked hose or a hose routing issue. Please help!!! I'm going to tackle this thing - it would be much easier if someone way smarter than me just said "look bozo - you have these two vacuum lines switched around behind the throttle body" or in front of the blower...
There are lots of threads on this topic - with varying results. I know mine isnt an actual SAI carbon buildup since that is done - but I am skeptical on the EGR/Combi *actually* being bad since it was a binary before/after modification that it triggered. This leads me to believe that it's vacuum related somewhere.. I just don't know where..
