Results 1 to 6 of 6
    Jun 26 2012
    Rockford, il
    DSG Clunk after Liquimoly Oil change
    Recently I did a DSG oil and Filter change on my S6, and I used the LiquiMoly 8100 Oil. So when coming to a stop I've noticed a 3-4 or 3-2 downshift clunk that the car didn't have before, it was OEM oil in there before. I've also used this stuff in my S4 with the DSG as well and it also had the 4-3 downshift clunk (I don't remember if it had it prior to me doing the oil change). I was just wondering if it's all in my head or if other people have had any of the same symptoms as me when they go to LiquiMoly 8100. Also why does this stuff have to smell so bad? the Oem stuff barely has any odor but this stuff is horrible and it lingers. Any feedback would be appreciated.
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Why didn't you use OEM oil?
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Established Member Two Rings kewe24's Avatar
    Dec 10 2011
    Des Plaines IL
    Is the fluid level correct? You have to check the fluid level while the transmission is at a certain temp.
    Jun 26 2012
    Rockford, il
    Quote Originally Posted by GilliamOS View Post
    I figured I could save a buck, OEM oil is twice the price at 6-7 quarts.
    Jun 26 2012
    Rockford, il
    Quote Originally Posted by kewe24 View Post
    Fluid level is correct I have a Vag-com and let it warm up to 40C before pulling the filler plug. I am an airplane mechanic by trade so I kind of know what I'm doing.
    May 26 2015
    Mormon Country
    Quote Originally Posted by Fociracr View Post
    I know with the ZF trans, there is no substitute for the original ZF-made fluid, no matter what the bottle says. The formula is proprietary to them and they do no license it out. I'd imagine it's a similar situation for the DSG trans fluid.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
