I had been loosing my mind because sometimes it seems more noticeable and can be hard to tell if it is the road surface but I have been able to repeat it now. It is really prevalent at 35 mph and it is getting more evident that it is in the front end as the steering wheel is beginning to shake. Above and below 35 I cannot tell that there is anything. 45 ish it tapers off and high speed on the highway it is fine.
I have had it a year. It is a 2014CPO S5 cab. When I go it I am sure there was no sensation like this. It took a beating this winter with the NE potholes. Blew two tires on the drivers front and hit plenty others. I had the tires Road Force checked last week. Firestone said all the rims were a little bent but not too bad. Only one required the tire be moved on the rim and they put the worst on the rear. It did not help the vibration.
I put spacers on a few months ago and there was nothing at the time so I do not think they are the issue. I pulled the rims and checked the torque and everything was good. I am going to take them off and see if they are part of the problem and definitely have them off before I go to the dealer. I am only going to the dealer to hoping it is something covered as opposed to something damaged from potholes.
