Results 1 to 26 of 26
    Feb 11 2017
    Oceanside, Ca
    More (some) Turbo noise!
    I want to hear my turbo damnit! What mod will help me? If it has a bit performance that'd be great too! CAI? Aftermarket DV? I am stock except for afe filter. Going to go stage 1 APR here pretty soon as well. Bring on the flaming and sporadic useful tip!
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Quote Originally Posted by novasteve View Post
    Any intake will make the spool audible. I went with a K&N Typhoon and it dramatically increased the sound.
    Active Member Two Rings quattroLM's Avatar
    Jul 25 2016
    Williamsport Pennsylvania
    I have a K&N typhoon intake that I'm looking to get rid of. PM me if you're interested and I can get you some pics.
    Sent from my XT1650 using Tapatalk
    Jan 03 2013
    Baltimore
    I run the AFE filter and forge turbo outlet (removed the "muffler" from the turbo outlet). I can hear things pretty well also am APR stage II.
    Sent from my Pixel using Tapatalk
    Established Member Two Rings stussy2870's Avatar
    Apr 04 2016
    Butler PA
    Quote Originally Posted by Nano909 View Post
    I second the K&N - LOUD AF!! You hear whistling, spooling, fluttering and the insanely loud PSHHHHHHHHH
    2015 Premium A4 Sline 6M/T, Dinan PiggyBack, K&N Typhoon Intake, Comfort Drop Spings, Niche Targa 20x10, RS4 Grill, Slotted/Dimpled Rotors and some G2'd Calipers
    Jul 25 2016
    California
    Quote Originally Posted by stussy2870 View Post
    Oh yeah, forgot to mention the blow off-like sound it makes. And that sound gets sharper with a GFB DV+.
    Feb 11 2017
    Oceanside, Ca
    Sounds like what I'm looking for. 2 questions, is it CARB certified and will it work on my car? It's a 2015 Allroad.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    AFE will make it his more.
    BOV if you wanna rice out.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Apr 04 2016
    Butler PA
    Is this something worth doing on a newer car? Im a turbo - noob.. dont know about what all these fancy gadgets do...
    Jul 25 2016
    The part number for the one I have is 69-9505T. I think it's only compatible up to the year 2013. So I guess probably won't work on your car.
    Jul 25 2016
    California
    Yes it's CARB legal. It comes with a sticker. Check the website to see what fits.
    Jul 25 2016
    California
    The GFB? Yes definitely. I didn't buy it for the sound. I bought it to replace the faulty OEM one (turns out it was the turbo) and I noticed much better throttle response right away.
    Jul 21 2004
    South Florida
    Keep in mind these cars sound like crap with open intakes. Its not like the B6 or even B7 cars. with open intakes under part throttle these cars make very audible and very weird groaning noises throughout the time the throttle is pressed. It will sound like the car is broken. It does not sound performance oriented at all.
    If you want just the nice blowoff sound, id get a spacer.
    Also be advised the K&N intake stretches out the MAF wife to maximum stretch. If you are hard on the car with launches the MAF wire can eventually malfunction. This is a definite design defect on K&N behalf and I brought it to their attention probably 5 years ago now.
    This gives you a good representation of it...
    2018 Audi S5
    Gone-
    Feb 11 2017
    Oceanside, Ca
    Quote Originally Posted by elscotto80 View Post
    Are you talking about this: https://www.forgemotorsport.com/VW_A...ct--1365.html#
    Jan 03 2013
    Baltimore
    Yes, I have that and I forgot to mention the GFB+ DV spacer.
    Don't add a BOV...
    Veteran Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    I just added one of these. Paired with an open intake you'd like like get a nice DV "flutter" sound. I just have the AFE drop in now and it does it sometimes, but it's not that loud. An HFC and/or tune may get you that sound more so too.
    https://www.ecstuning.com/b-forge-pa...iABEgI2f_D_BwE
    The DV Spacer will definitely get you an atmospheric BOV sound without throwing a check engine light, but just know that you'll be letting some air into the atmosphere that your motor thinks is being recirculated.
    Senior Member Two Rings shellraider's Avatar
    Dec 03 2015
    North Dakota
    Just be sure you keep your original airbox for when you go back to it. wiiiirrrrrr chuchu chu chu ssssssssssssssssssssss. I had a ECS luft-tech carbon. Great part, terrible sounds from the car. It's completely opinion based but mine was on for 2 weeks and this is how I felt after taking it off.
    2012 Monsoon B8 A4 Avant S-Line Prestige Package Black Optic : KO4, OEM Gauge Conversion, OEM Facelift LED Brake lights, OEM RS Interior Door handles, Full Engine Rebuild IE, Solid pipe, ECS intercooler, Porsche brake kit
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    Intakes are so cheap, That i just keep one so i can throw it on once in a while for some sounds hah
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by shellraider View Post
    I hear ya. These 2.0T engines are already pretty damn noisy on their own. No need to aggravate the situation.
    Personal opinion: If you want more sound go for an aftermarket exhaust.
    Jul 08 2015
    Quote Originally Posted by Tiggy View Post
    shouldnt be too hard to assemble a couple of pipes and a cone filter on ebay for 20 bucks lol
    Jun 07 2016
    Portland, Oregon
    Quote Originally Posted by JeriQo View Post
    Ok ill add to it. I do have that as-well. A winter setup and a summer set up..
    I just stuck a POD onto the end of the MAF and choo chooed away. (not recommended. Purely for sounds)
    Feb 11 2017
    Oceanside, Ca
    Does an aftermarket DV do anything for performance?
    Jul 21 2004
    South Florida
    Nope.
    2018 Audi S5
    Gone-
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Supposedly better throttle response. The gfb DV+ spacer adds a little sound at shifts too
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    Quote Originally Posted by bhvrdr View Post
    This is exactly why I chose the stealth mode on my B8.5. Stock intake (with AFE drop-in).
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
