Results 1 to 6 of 6
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Torque down upper control arm or leave it slightly loose?
    I know this might sound weird, or maybe stupid but when I removed my upper control arms, I found that the bolts that mount them to the strut hat was slightly loose enough where the arm can articulate any amount without putting stress on the bushing, but still tight enough where I would have to put a little force in them to move them. I drove my car like this for 2 years without any issues. I didn't even know they were loose.
    Now I'm installing new control arms, should I leave them loose as before? I will be lowering the car on coilovers so I know that's gonna change a few things.
    If I should torque them down, how would I do this with load on them? Any tips?
    Sent from my ONEPLUS A5000 using Audizine mobile app
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Ummm bolts should not be loose. There is a torque spec for a reason. Even if you can’t find the spec definitely make sure they’re tight.
    Two ways I tighten them with load.
    1) jack up the brake rotor to load suspension . Put a 2x4 in between as to not damage rotor. Tighten bolts.
    2) Put the bolts in and leave them a little loose. Install wheel, lower the car, an tighten.
    I prefer the latter assuming you can get to the bolts with wheel on.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by a4lownslow View Post
    yeah it can be tricky . Most times wheel is in the way , I wont jack on the rotor though . I usually jack under the spindle or strut to take the load. Of course GREAT CARE must be taken when doing this, and throw the wheel under the car as a safety precaution.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 15 2016
    Northern California
    how far would I jack? As far until the car starts lifting? Ive herd to go halfway and also all the way till just before the car lifts.
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Before you start, make sure car is level and measure from the center of hub to fender. This will give you your ride height when tightening the control arms. Investing in jack stands would be a more prudent safety precaution.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by StatusQuo View Post
    As you jack the spring will compress. As soon as the car starts to lift a little she is under full static load
    1976 Yamaha XS 360
