So I just bought a 04 audi A4 1.8t base that has no brakes. The peddle would go to the floor and the original owner claimed it was the master cylinder. So I went ahead and ordered a new Mc following a guide on how to install.
Couldn't remove the MC without unbolting the booster box. I basically had to loosen the bolts then tilt booster to pull out mc. I was told to bench bleed the new MC which I did off the vehicle, but could NOT rebolt new MC back in without removing the reservoir to get to the brake lines and the bolts for the booster and mc.
I did plug the reservoir holes temporary while I got the brake lines connected and mc/booster bolts in, I hope it didn't let more air in. Popped reservoir back in and peddle still goes to floor while pumping brake peddle a little.
I'm sure I still need to bleed the brakes but have no pressure bleeder, I did buy a kit from harbor freight not sure if this will work. https://m.harborfreight.com/brake-fluid-bleeder-92924.html
Also I see lots of people saying to bleed brakes FL, FR, RL, then RR. Then I also see some saying RR, RL, FR, FL so which is correct?
