Results 1 to 8 of 8
    Junior Member One Ring
    Oct 24 2017
    Orange County, CA
    Proper brake bedding?
    Installing akebono pads with Zimmerman rotors rn from the recommendation of fellow members here. Wanted to get some advice on bedding the brakes properly.
    Mar 28 2016
    There's no one right way to do it, but get the brakes up to temp, then do a series of 60-10MPH stops without coming to a full stop. Then drive around normally for 5-10 minutes to let the rotors cool before coming to a full stop.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I have never bedded new pads on any of my many cars, over the last 35 years, and have never had an issue. I think it is only some high performance pads that need bedding...not normal street pads..I put Akebonos all-around on my S4, and did not bed them. 5000 miles later, all is still fine with my brakes. Street pads are typically pre-baked by the manufacturer, to fully cure and outgas the volatiles in the friction material mixture.
    Apr 16 2017
    Illinois
    Do 5 or 6 60 or 70 mph to 10 MPH hard stops with minimal cooldown time. Then, drive for 5-10 minutes without coming to a full stop and you're good.
    Veteran Member Three Rings AFR1485's Avatar
    Nov 24 2015
    Fiat 500
    Bedding is only needed if the brake pads require it. Akebono pads do not require bedding.
    Rotors don’t need bedding, especially since you should be installing new pads whenever you change rotors.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Mar 28 2016
    Quote Originally Posted by Bartlett View Post
    This post is seems.....familiar.
    Apr 16 2017
    Illinois
    Quote Originally Posted by hilmar2k View Post
    I didn't even read your post but I now see that it is very familiar rofl
