Results 1 to 6 of 6
    Established Member Two Rings S5_01's Avatar
    May 19 2016
    Charlotte, NC
    bilstein b12 prokit noises
    Have had the Bilstein b12 prokit on my s5 for about 2 months now. As of one week ago, the left shock makes a rattle noise going over small bumps at very slows speeds (0-5mph). It almost sounds like plastic against plastic noise. We had a big rainstorm here about 10days ago and i drove thru about 1inch of water. Its been making noise ever since then. Not sure if its a coincidence or the cause. Also now the rear when going over small bumps/drops in the road or driveway makes a metal clunking noise. Anyone have similar issues with their B12 Bilstein Prokit?
    2014 S5 | Ibis White | S-Tronic | Kohlefaser Lufttechnik Intake | CR-15 | Alu-Kreuz | Bilstein B12 Pro-kit | Adjustable Control Arms
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    My money is on installation rather than the equipment itself, have you taken it back to the shop who carried out the install?
    May 19 2016
    Charlotte, NC
    Quote Originally Posted by JamesRS5 View Post
    Im going to be dropping it off tomorrow at the shop.
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    I had a similar sound / issue with my B16 install and it drove me crazy. Turned out to be the top jam nuts / bushing were installed improperly. The noise didn't rear its head until a couple of weeks after the install. After arguing with the out of town shop, I ended up correcting it myself.
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2016 Q5 Premium Plus 3.0T, S-Line, Exclusive Derby Green Pearl
    *2019 A6 Prestige, Mythos Black, Night Vision
    *2008 Toyota Tundra SR5, bone stock
    May 19 2016
    Charlotte, NC
    Quote Originally Posted by Twotonicnite View Post
    Yea shop is saying now i have to replace thrust rods, bushings, and upper control arms for a grand total of $3500 if i want to go with OEM parts....
    Feb 27 2014
    Dubai
    The UCA’s bolts should always be tightened with the suspension loaded, if they tighten them with the suspension drooped the bushes will fail pretty quickly.
