Results 1 to 4 of 4
    Junior Member One Ring Lachneyjames's Avatar
    May 31 2016
    2011 Land Rover Range Rover
    Baton Rouge, La
    2011 S5 Power Steering Leak
    Cannot find too much about this on the internet, so I figure this doesn't happen much. Maybe you guys can help.
    I got in my car last night after dinner and stated it up to head home. I put it in drive and noticed as the engine increased, there was a loud whining sound. It would get louder at some stop lights and lower at others. Once I got home, I messed around with the wheel and notice the sound would change with the turning of the wheel. I popped the power steering cap and found the fluid was too low to be seen. I filled the reservoir with the fluid I picked up from Audi today. It was a half pint low. There is clearly a leak. Has anyone had a power steering leak on their B8 S5? If so, where and what had to be replaced?
    Also, keep in mind. I started this thread to help document this issue for others that my find themselves in the same position.
    May 31 2016
    Baton Rouge, La
    Update: I got the car up on ramps and took a look under it. I found the driver side tie rod boot was dripping and the passenger side boot was wet. I called up the dealer for a price on a new rack. They quoted 1338.00 for the rack with out labor. How hard is it to change yourself?
    Jan 03 2018
    2011 Audi S5 & 2018 Jeep Grand Cherokee
    Cleveland Ohio
    I'd start by not taking it to the dealer. Is there a garage that specializes in Audi/VW or just German cars in general? I've found that, aside from basic bolt-ons, its best to leave big things to the professionals but then again I do not have an understanding of your ability in car maintenance.
    May 31 2016
    Baton Rouge, La
    Update: This project is surprisingly easy! The only tools most people don't have, that you will need are a tie rod separator and a set of triple square bits. I will work on putting together a step by step in case anyone needs it.
    FYI - I got two quotes for this job. Audi wanted $2200.00 just to replace the rack. Did not include fluids or tie rods. I had an independent shop price the whole job. Rack, tie rods, fluids and alignment. They wanted $3,500.00.
    I completed the project myself in 4.5 hours. I had to bring it in for an alignment. To complete the job myself, I am all in at $833.00.
