I found a 1999 (and a half?) A4 with a 2.8 v6 for $350. It SOUNDS like the valves got into a fight with the piston, so I am assuming the motor will need to be replaced. (I am basing this off of the clist description as well as the fact that when the timing skipped on my B5 S4, it was bent valves.) I am familiar with the engine out procedure for a B5 S4, and am just checking to see if there are any parts of the process I am missing.
From the clist description:
"I have a Audi never had a problem with it timing belt snapped I replaced the belt water pump and pullie tried to set it a time my self tries to start it sounded like it wanted to start makes like farting nose if it makes sense I'm done trying my loss is you're gain new tires breaks and rims still have receipt for them as well ass all maintenance receipts CLEAN TITTLE PINK SLIP IN HAND JUST ALONE IN PARTS U CAN MAKE A PROFIT FIRST WITH 350 takes it all I'm not parting out selling AS IS THANKS NAMES ANTONIO HMU IF U HAVE ANY QUESTIONS"
eg:
- If i swap in a new motor, will it fire right up? Do I need to "recode" the ECU or anything?
- What if the motor came out of a tip car? This one is 5MT, so its different from that standpoint.
This is around the goal for the car
- 31" knobbys, fender flares, "massaged" wheel wells, light bar, etc
