About a year ago I purchased a used 2006 A3 2.0 bpy from a private seller. On the drive home I realized there were gonna be some issues. A year later, after a B cam, new chain and tensioner, hpfp, high pressure rail sensor, coolant sensor and thermostat and other stuff that would take too long to list, I'm still getting an intermittent p2293 code. Obdeleven is going through some revisions so I can't check the lpfp duty cycle. Along with the code I get the occasional hard start that sometimes accompanies the code. I've logged group 230 during a hard start and have seen that the requested bar is 50 but the actual is 6 bar. Other times the actual bar will be over 100 and the car turns right over. The group 106 readings are right were they should be. I've even logged 231 through hard acceleration in 3rd and 4th grade and everything is right were it should be. Suffice it to say, in stumped. If the group 230 readings are not what they should be where else should I be looking, the prv??
Thanks in advance for any ideas!!-- Al
