Results 1 to 9 of 9
    Established Member Two Rings kwaceyoopony's Avatar
    Jan 03 2017
    Bothell, WA
    Need help replacing transmission mounts on a C5 (2001) A6 4.2L quattro
    My car shakes on acceleration and im pretty damn sure its my mounts. Does any one have any detailed walkthroughs on how to replace the mounts? How many mounts are there? Should I go with after market mounts or OE?
    Thanks in advance guys!
    Senior Member Two Rings S/RConcepts's Avatar
    Jan 10 2018
    Illinois
    There should be 2 transmission mounts. Looks really straightforward, I'll attach the page from the service manual below.
    As far as what mounts to use, I hear really good things about the 034 Motorsport Density Line, and they're probably way cheaper than the Audi OEM to boot.Screenshot (2).png
    Jan 03 2017
    Bothell, WA
    Do the 034 density mounts fit the 4.2L? i see that it says it fits the A6/S6/ALLROAD but it says it doesnt fit the 4.2L...
    Jan 10 2018
    Illinois
    There's a lot of conflicting information regarding the 034 mounts... some say yes, others say no. I guess the only way one could really find out is to buy a set and try them.
    However, ECS Tuning has Rein mounts for the 4.2 at a really good price: https://www.ecstuning.com/b-rein-par...b0399151m~ren/
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by kwaceyoopony View Post
    I've been driving C5 Audi cars for a long time, and pretty sure it's not going to be the trans mounts ...
    Check the CV joint boots for tears and the shafts for play at both inner and outer joints ;
    Check all 8 control arm inner rubber bushings for cracks and/or tears in the rubber ... if they're dry and brittle they need to be replaced;
    Check the inner and outer tie rod ends for play;
    Go forward from there ...
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jan 03 2017
    Bothell, WA
    Quote Originally Posted by 02 A6 2.7T View Post
    I recently replaced the cv axles so they shouldn’t be torn or anything I also have after market upper control arms. I’ll check all of it but I feel like I should still replace the mounts since the car is 18 years old and I’m sure they have never been replaced. I appreciate your advice man!
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Transmission mounts were one of the easiest things I did on mine, shouldn't take you hardly any time at all.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Jan 03 2017
    Bothell, WA
    Quote Originally Posted by carmudgeon View Post
    Ok cool! Good to know thanks man.
    Oct 30 2009
    Miami, FL
    They're super easy, but specific to the 4.2 only. I'm not sure who makes the OEM mounts, but avoid the cheap brands to play it safe.
    Sent from my MI 5 using Tapatalk
    2018 S5 Coupe - stock for now
