So I just got an '02 A4 3.0 from my stepdad about 4 months ago. It currently has 294,000 miles on it, and I'm concerned it won't last a whole lot longer. From what little I know about the vehicle history, the majority are highway miles, and I have a list all work done to it that I will add later. I'm just wondering what I should be concerned about, and what I would start to notice if it were to "call it quits" anytime soon.
-------------------------------UPDATE-----------------------------
Chronological maintenance history:
104k Serpentine belt, tensioner, 3 ignition coils, plugs
107k Timing belt, water pump, seals.
134k All 6 coils (recall?)
181k Timing belt, water pump, seals, tensioners, rear brakes
228k Front brakes
240k rear pads/rotors, plugs
241k clutch and flywheel\
This was what was written in the notes section in the manual, as well as regular oil changes, tires, etc. It doesn't seem like much if any suspension work has been done.
I replaced drivers side steering knuckle within the past 2 months. Will look through receipts that I have to see if original owner missed anything in the history. Just found a disturbing note on one of the receipts from 181k saying "Exhaust lifters are deteriorating, will destroy camshafts if not repaired - cust. declined". Haven't seen anything else related to cams, lifters or any other upper engine work. Assuming this is something I should look into given that that was over 100k ago?
