I started noticing a squeal/squeak when letting off of the clutch that goes away once the pp fully engaged. Kinda sounds like a squeaky belt also.. car has clutch fan delete with OEM belt.. I'm just curious if you experienced folks would say this is a sign of the TB failing soon or anything I should worry about fixing, or just leave it as is.
Clutch set up is AMD stage 1 with B7 rs4 PP and has a few thousand miles on it..
