Originally Posted by
Hawkdriver
I currently have Stoptech ST-60 up front with 380mm rotors. I track the car often and it would really be cheaper to use 18" wheels and the appropriate size tires. There's not a whole lot of R compounds out there in 19" fitment. I can't fit an 18" wheel over the 380mm rotors so I'm wondering if I can just change out the rotors for 355mm when the current ones wear out. Will I have to change any other parts, like the calipers to use 355mm rotors?
You might be better off selling the ST60 kit and getting a 355mm kit. I run the 355mm ST40 kit and it's plenty sufficient for even hard track use, plus pads are super cheap and compounds are plentiful because it is a common Porsche size.
Otherwise, it's just a different bracket and rotor size (you'll need new hats too), except that the brackets can be a bit difficult to source and are expensive (well over $500), as Stoptech or Brembo don't want you utilizing brakes on something it wasn't originally designed for, even if the kits are identical.
