Results 1 to 11 of 11
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Anyone here running Bosch F5DP0R side fires?
    I've been experimenting with plugs to try to eliminate this mystery misfire and the ones that ran the best were the triple ground plugs but they fouled out in less then 2000 miles. Anyone have any experience with the Bosch F5DP0R side fire plugs as recommended by JHM/CTS? What have you guys had the best luck with?
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by Spawne32 View Post
    You were using the FR5DTC before right? If those fouled up there is an issue somewhere else because those are one of my favorite plugs ever.
    When does the misfire occur?
    Nov 20 2016
    Quote Originally Posted by Jake@JHM View Post
    I have a cold start miss and a nasty hesitation between 3000-4000rpm right about when full boost comes on, leaned it out to about 12:1 AFR under WOT but other then that everything checks out. Only thing I can think of is it needs injectors because ive done everything else I can possibly think of.
    Aug 31 2011
    Lathrop
    Injector is a big possibility, we have to replace injectors on several B8 A4s locally.
    Do you have a cat on the car?
    Nov 20 2016
    034 motorsports HFC with brand new o2 sensors and gaskets when i did it
    Aug 31 2011
    Lathrop
    Have you inspected the catalyst?
    Nov 20 2016
    For what? it wasnt clogged if thats what you mean? have you used these F5DP0R plugs?
    Aug 31 2011
    Lathrop
    Yea, specially after the misfiring. We had seen it happen before where a partially clogged cat was causing hesitation at a particular RPM range.
    Yes, they are fantastic plugs. I just prefer the FR5DTC because they are cheaper.
    Senior Member Three Rings Jezza's Avatar
    Dec 14 2016
    Tuscaloosa/Alabama/South East
    Are you sure you don't have a vacuum leak somewhere? If you have a a turbo muffler delete, especially the one from CTS, take it out and check the seal. Mine was blown (looked melted) and replacing it with rtv silicone smoothed out my idle and improved my fuel trims. I need to get a new seal to make it permanent. The rtv silicone was not a permanent fix. Its back to idling rough and poor fuel trims. I'm guessing the rtv melted or failed under boost.
    Sent from my SM-G930VL using Audizine mobile app
    "Big" Mods:
    -APR turboback exhaust w/ gutted HFC
    -Intake
    -Treadstone TR8 intercooler
    -2014 A5 engine to fix the oil issue (REEEEEE)
    -Eurodyne Stage 2 tune (I did it myself. Fingers crossed.)
    Garage:
    2011 Audi A5 2.0T 6 MT
    1978 Dodge W-150 (318 cu. in. V8 w/ 4x4)
    2015 VW GTI SE two door DSG (Wife's)
    Nov 20 2016
    I checked the cat when I put it on several months ago, catalyst looked good. No turbo muffler delete, stock turbo setup with silicone hoses and the ECS intercooler. I've checked it for vacuum leaks, nothing i can locate, no excessive vacuum in the crankcase at all. Intake ports were cleaned last year, new timing chain/tensioner, new vvt control valve, new cam actuator magnet, fixed the broken screen on the cam bridge. New intake manifold as well.
    Nov 20 2016
    I get them for about $10.23 a piece, which isnt too bad if they will solve my problem and last a bit longer then the copper plugs. I am showing the stock heatrange as being 7 for NGK and that cross references to a 5 on bosch, so these are both factory heat range plugs you recommend? No real reason they should have fouled out unless the car was running rich which I haven't found anything out of the norm thus far. It's not a k04 car but i have the k03 running balls out, a little over 20psi at WOT.
