Results 1 to 16 of 16
Thread: Exhaust
    Established Member Two Rings Big_Reyn's Avatar
    Aug 15 2014
    2002 GMC Sierra, 2005 Toyota Camry, 2018 Infiniti Q50
    DFW
    Exhaust
    Thinking about putting magnaflow's on my 2011 a6 3.0t. For those that have replaced the stock mufflers please give me your thought. Which muffler sounds best with minimal to no drone. I will possibly be doing the resonator too but will start with mufflers first. Thanks in advance.
    Sent from my Pixel 2 XL using Tapatalk
    Established Member Two Rings iconic_eric's Avatar
    Jun 21 2015
    2010 3.2 Q5, 2004 1.8t B6, 2007 C6 3.2 A6
    Providence, RI
    Bump, thinking about doing the same thing
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    I heard that changing the center to an x-pipe makes a good difference. There are a few threads on here already. Search them out
    Sent from my SM-N950U using Tapatalk
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    I'm sure @sincitya6 will chime in here, but pulled a post of his to highlight his experience with his setup.
    Kneel, I am running a Magnafow resonated X-pipe (where the small resonators were), then straight pipe back to Magnaflow mufflers and 4” tips. I kept the stock 2.25 inch tubing.
    Drone is evident at 2k rpm while under load and goes away at around 2500. My wife complains about it when on the freeway doing 75 (6th gear @ 2000rpm) so I just kick it into sport mode and drop to 5th) engine revs at about 2500 rpm and drone goes away. I thought I would see a significant decrease in MPG but it’s less than 1mpg.
    The one unknown is that you have an Avant and mine is a sedan. I don’t know if the extra volume in the passenger cabin will have an impact.
    As for price, my setup was $650 installed having sourced the items off Amazon.
    I'm planning to go a similar route, so just trying to decide if I want to deal with the drone, or change it up a bit to try to eliminate it.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Jul 17 2011
    Sin City, USA
    Exhaust
    As stated above, there are several threads that discuss this.
    The OEM system has 2 sets of resonators; small in front (2) and larger “triangular” shaped ones (2) about mid cabin (they sit on either side of the driveshaft). I removed everything from the small resonators back.
    From my research, removing the resonators, not mufflers, increases drone. However, swapping mufflers only doesn’t really give you much change in sound. I don’t really think the drone I have is bad, plus it is only in one area of the rev range when under load; 2000 rpm.
    Here is a video I did for @kneel about drone:
    https://youtu.be/RSIFVGL_Ahs
    Here is a cold start video:
    https://youtu.be/IBse25lbOCg
    Here is a clip of driving (don’t mind the video quality):
    https://youtu.be/z2kKetq9IiE
    '09 C6.5 A6
    Senior Member Three Rings dluxxx's Avatar
    Mar 13 2013
    2016 Porsche Cayenne Diesel
    Nor*Cal
    I could attest to your research sin, once you remove resonators drone will be evident. The last video will have interior sounds of my current setup where you can hear the drone at around 2k rpms. Also if you need some sound clips I have them with Magnaflow mufflers:
    Magnaflow Mufflers + Magnaflow Resonated X-Pipe (Midpipe) + Stock front Resonators
    https://youtu.be/gp6WhSdYE7s
    Magnaflow Mufflers + No Midpipe Resonator + Stock front Resonators
    https://youtu.be/tAeklM2oSFY
    Remus Mufflers + Magnaflow Resonated X-Pipe (Midpipe)+ Stock Front Resonators
    https://youtu.be/E9816-PQnXI
    Above Setup (Exterior + Interior sounds)
    https://youtu.be/6UK3q-xtv3I
    2010 A6 C6.5 3.0T, Remus Mufflers w/ Quad tips, Magnaflow Resonated X-Pipe, RocEuro Intake, EPL Stage 1, Transparent Gloss Copper Verde Axis V99 20x9, Michelin Pilot Sport 4S 265/30, Bilstein P14 PSS Coilover, H&R Rear Sway Bar, Ultra Racing Front Lower Brace, Ultra Racing Center Lower Brace, RS6 Black Gloss Grill, Rear diffuser, Black Vinyl window trim, Smoked Rear Tailights, Complete Interior LED Lights, Blacked out front sidemarkers, Morimoto 5000k D3S bulbs, SB3 Alpha Ceramic Coating.
    Veteran Member Three Rings Edvan's Avatar
    Apr 22 2012
    EAST ELMHURST, NYC
    Quote Originally Posted by dluxxx View Post
    Dluxxx can I get part number for Magnaflow mufflers Thanks
    Established Member Two Rings addicTT's Avatar
    Aug 06 2010
    Hampton Roads, Va.
    I'm planning to remove both sets of resonators and have the Magnaflow x-pipe and some new oval slant cut resonated tips to squeeze in. Thinking of doing some Helmholtz resonators for the drone. I'll try to post pictures and video when it's done.
    Mar 13 2013
    Nor*Cal
    Quote Originally Posted by Edvan View Post
    Resonated X-pipe 11385
    Mufflers 12225
    Apr 22 2012
    EAST ELMHURST, NYC
    Mufflers 12225
    Thanks which dual tips are you using ?
    Aug 06 2010
    Hampton Roads, Va.
    Got some pictures of the exhaust work and a short video today
    https://photos.app.goo.gl/chWCfujmN8LdH3x13[IMG]https://photos.app.goo.gl/zMr1rxhG9ieTOJqh1 https://photos.app.goo.gl/UQD9XxYwBdo4EWkB2
    Daily driver, 2009 Audi A3 Quattro 2.0 TSFI, only mods so far are a BSH race intake and a Milltek exhaust.
    Aug 15 2014
    DFW
    Quote Originally Posted by addicTT View Post
    [video]https://photos.app.goo.gl/chWCfujmN8LdH3x13
    Sounds good. Exactly what did you have replaced? I want to do some exhaust work to my a6. BTW, I have the same color.
    Aug 06 2010
    Hampton Roads, Va.
    All 4 resonators removed, Magnaflow x-pipe and new tips
    Aug 15 2014
    DFW
    Is there much drone? Is the x pipe resonated? Thanks.
    Aug 06 2010
    Hampton Roads, Va.
    Yes, it's resonated and I haven't noticed any drone yet, quieter than my previous TT and A3 which both droned.
    Aug 15 2014
    DFW
    Thanks
