The wheels were just repainted by Pittsburgh Powder Coat and have not been installed on the car since. I also have a set of Bridgestone Pole position tires that I will give you. The tires only have about 1 summer left on them. Includes Plastic centering rings, lug bolts, and center caps. The center cap picture below is what they look like but you will not receive the ones in the picture. These have broken tabs on the back but I ordered a new set that should be in around June 1st. Below are the specs on the wheels and tires.
Asking $1,100. No trades. Local Pickup
Wheels:
Offset: 38mm
Bolt Pattern: 5x112
Weight: 22lbs/wheel
Backspacing: 6.30"
Construction: 1pc low pressure cast w/ flow forming
Tires:
Bridgestone Pole Position
255/35R19 96Y
