Results 1 to 40 of 56
    Established Member Two Rings Eclemente's Avatar
    Apr 19 2016
    Kings Park, NY
    Ultra High Performance All Season Tires
    Can someone please direct me to thread discussing Ultra High Performance All Season Tires? Thanks!
    Nov 28 2015
    Montreal, QC
    just get PS4S and call it a day lol.
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Continental DSW
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Senior Member Three Rings mcjim's Avatar
    Nov 13 2006
    Atlanta
    Quote Originally Posted by waxxonMTL View Post
    Those are not all season tires. I can tell you from exp these are not great tires in low temps.
    Current: 2014 S4
    Sold: 2008 911
    Sold: B6 S4
    Sold: B5 S4
    Sold: B5 A4
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    There is no such thing as "ultra high performance all seasons" least not in reality. They market shit with that title, but it is a farce
    All seasons as a tire are a farce. They are a lie. They are compromised in every single category of performance. You own an S4, you should have 2 sets of tires. This isn't a budget carolla... this isn't a small SUV driven by your girlfriend, its a fucking performance sedan.
    The reasons they are POS tires is as follows:
    The main facet of a tire that provides its grip is its compound. The tire compound is the single most important attribute of a tire. That compound is designed to work within a specific temperature range and operating temp. Summer tires are harder in compound and are designed to handle and perform at their peak performance in hotter temperatures when they are pushed in things like spirited driving. Winter tires are softer. The softer compound is designed to work and remain soft in cold temperatures. The compound itself allows the tire to actually deform around the imperfections in any and all surfaces the tire is rolling over and that is where your grip comes from. The actual cut of the tire is really only there for surface contact and water evacuation except for the mini cuts in a snow tire which allow for further deformation around imperfections in the road to also provide a moderate level of additional grip. With summer tries, the compound, when too cold, will not deform at all or get warm enough to operate properly and will actually splinter itself into oblivion.
    Now for All Seasons:
    The reason they are garbage is because they have to be made 1 of 2 ways. The first is an in-between compound which is "acceptable" in both hot and cold weathers, deforms enough but not too much where it destroys itself in the summer and winter. The entire contact patch and sidewall are made of the same in-between compound which is basically good at nothing. The compound is not hard enough to really push the car and not soft enough to truly give you desired levels of grip in the winter.
    The second is when they put different bands of the compound together. This means that one section of the tire is a warm temp compound and the other is a cold temp compound. This means that x% of your contact patch in the opposing weather is fucking useless. Therefore, no matter what "all seasons" you get, you are compromised and riding on shit tires.
    Now, if you are a slow driver, a grandma, a pussy, or someone who doesn't give a fuck (most the population on the roads fall into the last one) then go for all seasons. If you lease, go for all seasons, if you live in a part of the country that never sees winter, buy all seasons, but do not come onto a forum driving a S4 and ask for the "ultra high performance all season" especially when living in a state that sees winter and snow every single year!
    Its a fucking joke.
    Sorry to be an asshole, but All Seasons really grind my gears.
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Apr 29 2013
    Detroit, MI
    I ran a set of DSW 06's through three Chicago winters without issue. Even did an ice driving event on a frozen lake in Wisconsin on them. Also didn't have a chance to swap my summers every year, so ran them year round for awhile and they performed well enough.
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    Mar 28 2016
    Quote Originally Posted by Gberg888 View Post
    Its a fucking joke.
    I beg to differ. There absolutely are some all season tires that perform quite well. Do you sacrifice some summer performance? Sure. Are they as good in the snow as dedicated winter tires? Of course not. That said, unless you drive your car like you're always on a track, or live in an area that gets crazy snow, a good all season performance tire works just fine. Here are a couple I have experience with:
    BF Goodrich G-Force Comp-2 A/S (had them on my TT and my A6)
    Cooper Zeon RS3-G1 (buddy has them on his Jag and loves them)
    Toyo Proxes 4 Plus (current tire on my S4)
    I drive fairly aggressively and never have any issues with grip. They are all great in the rain, and good enough in the snow in combination with AWD. Obviously 2 sets of tires would be ideal, but certainly not necessary.
    Oct 14 2012
    Empty...for now...
    SE PA
    I ended up with three sets of wheels and tires - and 18" winter setup (Michelin Pilot Alpin PA4), 19" all-season setup (Continental DWS), and 19" summer setup (Michelin PSS). I didn't really plan for it to work out that way, but it happened. It works out really well for me here in PA where the month of March (and sometimes into early April) the temperature fluctuates 30-50 degrees F and maybe it snows, maybe it doesn't. Same sort of thing happens late November in mid-late December. During those months I run the all-season setup which is a good compromise. It's a bit of extra work and storage space for the extra set of wheels+tires, but worth it to me. That being said, if my winter setup was 19" and not as egregious looking as my current 18" set, I might be inclined to just keep the winters on until I'm 100% sure the snow and freezing temps are done.
    SOLD 2015 Daytona Gray S4
    Senior Member Three Rings EAFLO88's Avatar
    Dec 08 2016
    Texas
    Don’t be an idiot and stay away from anything all-season. I’ve had Michelin A/S 3+ & Cont DWS 06. I learned to hate them both.
    Mar 28 2016
    Quote Originally Posted by SteveYem View Post
    Yup, that's the issue with running dedicated summer and winter tires. I did when I had my MB E500 (RWD, snows were a must). First spring after I had the car I swapped tires back to summer. Three days later, a foot of snow and I was screwed. So lesson learned, right? Next spring, nope, not switching just yet. Three days later, 80 degrees outside and I destroy my winter tires.
    I just don't understand all the all season hate. I guarantee you've never driven on a really good set if you have that opinion.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by hilmar2k View Post
    Yes, exactly. All season tires are better than running winter tires on warm days, or summer tires are cold days. They area good interim solution for the couple of transitional months that we have in the northeast US. No offense, but I would not expect the guy from Houston to be as receptive to it (and yes, I understand that it occasionally gets down into freezing temps in southern Texas, as an outlier condition).
    Senior Member Two Rings jcpowell's Avatar
    Oct 18 2017
    Somewhere, GA
    Yeah I really don't get two things. 1. Why people on here pride the S4 as this fucking super sedan that only rich people drive. Don't get me wrong, I love my car but it also cost me under 30k. 2. How can you diss all seasons like everybody lives in the same driving and climate conditions as you.
    I live in Georgia where we rarely see snow and if we do it's become a state of emergency (lol). Occasionally I'll drive it up to the mountains where there's gravel and dirt roads at steep inclines..all seasons come in handy here over full summer tires. Not everyone on here wants their S4 to be a race car. With that being said, I've been using Yokohama Advan Sport A/S and they have proved to do quite well in a variety of conditions, including a little spirited driving on a hot day.
    2018 Brilliant Black S6 Prestige | APR Stage 3+TCU & downpipes | SRM RS7 Turbos | H&R Sway Bars | RS Grille | Sport & Black Optics Package, Alcantara Headliner
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by maty360414 View Post
    Continental DSW
    +1
    I just replace my dws with dws06... marked improvement upon any little gripes the dws may have had (squishy or soft if not running high psi, now not an issue)
    love, love, love the dws06
    great job conti keep it up
    also, I run 2 sets of tires since I live in the north east... winters and "ultra high performance all season" dws06... can't tell you how many times the dws shines in the spring and fall cross over periods where you still have frost nights... allows me to run summer wheel setup at least 2 additional months in the year and be 100% safe... and honestly, compared to a dedicated summer tire, unless you're tracking it or need 100% performance all the time... I'll stick with my 90%+ performance and be safe, comfortable and have longer treadlife all at a great price and look
    but for somebody who wants a true all season performance tire, the dws and dws06 are the only true options
    just imho
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Mar 28 2016
    Quote Originally Posted by 01northernS4 View Post
    +1
    You run those year round? I am considering those as a replacement for my Toyo Proxes 4 Plus come winter.
    Jun 16 2011
    996tt
    MA
    Well first off, you may have bought it for 30k,or 20k or, 18k, but that does change the fact that new it was 55-65k sedan.
    Second, if you do live in Texas or Georgia, or any of the states that see snow once every 10 years, then all the power to you to only have summers and/or an all season for the non summer months. The thing is, the OP is from NY. He is looking for a 1 tire solution, and that does not exist when you can go from 100 degrees to -15 degrees and have all types of precipitation through the four different seasons of the year. When you slide into the back of someone because you tires don't get you the grip you need during a snow storm, that extra 4-8 ft of stopping distance saved is the difference between a new front end and getting away with a small poo stain in the pants...
    Finally, AWD in these cars and any car makes barely a difference. The only thing touching the ground in the tires, therefore, they are the only thing providing grip. You run shit tires you get shit grip. Sure, awd will help in certain situations where 1 or 2 wheels are spinning because they have no grip, but in a driving/sliding situation, it dont matter. Its all about the tires. You cant just rely on your "AWD" to save you and allow you to run crappier tires.
    Garage:
    Oct 18 2006
    Audiville
    I have run them in the winter and unless you are in terribly deep stuff (like a foot, lol) they do great... I now run winters as I get an insurance discount and the roads are terrible here in the winter with potholes and such so why not but I'd have no problem doing so from a performance and safety perspective
    Oct 18 2006
    Audiville
    Quote Originally Posted by BaumerS4 View Post
    +1
    Mar 28 2016
    OP is from LI. My guess is that there are single digit days per year where a snow tire is really needed. So you are sacrificing a lot to drive on snows for those 6 days. I live further north than the OP in the Hudson Valley. We get more snow. I drive on good high performance all seasons and never have any trouble in the snow. Buffalo? That would be a different story.
    Oct 18 2006
    Audiville
    agreed, great response
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    If you live a a place that has a clearly delineated summer and winter, AND have the money and storage for 1 summer set and 1 winter set- this is definitely the optimal route. However, if you live in a place like I do, where it snows an inch one day and the next day it is 80'- all seasons make a lot of sense.
    As far as which tire is best- I tried the Continental Extreme Contact DWS and it rides really nice, is cushy (perfect for a city with potholes), and has good straight line grip (compared to other all seasons), HOWEVER, the softer sidewalls are terrible if you take windy back roads or canyon carve- I mean they are like driving a bouncy castle. I had the Continentals removed and installed the Michelin AS3+'s. MUCH happier with these. I guess they are the top rated tire in this category, for a reason.
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by mcjim View Post
    then get winter tires and run 2 sets. No such thing as high performance all-season tire lol. You can't have both the Nokian Hakka 9 winter grip and Michelin PS4S summer grip at once lol.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Lol at blowhards. Every tire is a compromise. There are scenerios between PS4S and studded Nokians.
    The DWS are more than capable in winter. There has extremely squirmy sidewalls when I ran then. The DWS06 are supposed to be better, but the Tire Rack test mentions week steering response.
    I ran AS3s right now, pretty good tire, but I don't trust then in any kind of snow. I don't have a pit crew and we can have snow one day and 70 weather the next, so something that can get you through a couple of light days a year without being crazy (like full on summers) are good to have. Plus, they typically have some better treadlife.
    Jun 16 2011
    996tt
    MA
    His location says Kings Park NY... hence my anger...
    Garage:
    Mar 28 2016
    Which is on Long Island, which doesn't get much snow.....hence my immediate dismissal of your anger.
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    Two sets ftw if you'll see snow more than 10-15 days per year or genuinely think you'll need all the traction you can get for the driving you'll be doing.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by cjw View Post
    I've read mixed reviews on the DWS06, but regarding steering response I wonder if it gets better as the tires wear in, and whether the reviews of poor steering feel are based on the first XXX miles?
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    Ive been running A/S 3+ since that's what came new with the car when i bought it in Feb. Driving 900 miles back through an ice storm they handled great in the slush, and now that the weather is back to 80s in Kansas they seem to run pretty well. Obviously i'm not canyon carving or anything but the spritited on-ramps or ambitious back road corners have been great. I am planning on getting a set of proper summers soon, and will keep the A/S3s until they wear out and I get a set of winters. plan on moving to Minnesota in a few years so will probably invest in another set of all-seasons for the few weeks in between summer and winter up there.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    There is a reason new cars typically come with A/S tires and that they are by far the leading seller across almost all tire brands. They bridge the gap and do it decently. I am sort of a "tire snob" myself, running the OEM 20" summer tire package on my new Q5 and running Yokohama AD-08R extreme performance summer tires on my little hot hatchback. When the Bridgestone summer tires on the Q5 need replacing I will go with the best available summer tire. So, I have no prejudice against summer rubber.
    My Stage 2 3.0T Q5 is classified as a "small suv." It is not a girlfriend or soccer mom car. It is my work car. In its current state of tune, it runs mid 12's with a 0-60 of 4.3. That is better than stock S4 and most stage 1 S4 cars. I may add cooling and go double pulley ratio later this year. I did get the summer tire package, but it seems that those with A/S rubber are doing just about as well on all but road course lap times.
    But, we run A/S UHP Michelin tires on my wife's S90 Volvo and similar Cooper tires on my full size Nissan Armada SUV (actually more of a M/S tread).
    Yes, A/S tires are not as good as dedicated summer tires for aggressive summer driving and give up a lot to dedicated winter tires in the snow.
    I'm in south Mississippi, so no snow here. We do get icy roads in Jan/Feb, but only for a few days. A/S work fine for us under those circumstances. On those days, I keep the summer tired cars garaged and drive the Armada.
    There are many instances in which an A/S tire makes sense, even on a performance car. Were I to run an A/S on a high performance car it would be the current Conti DWS 06, and yes, it is properly classified as an UHP A/S tire. Ran Pirelli P-Zero Nero A/S on the hatch for a season and they were terrible. But, that was the tire compound and tread design and not that it was A/S. It was horrible in the wet.
    Oh, and for those on a budget, A/S tires will typically have a much longer tread life than the soft compounds on the dedicated summer tires I run.
    https://www.tirerack.com/tires/tires...Contact+DWS+06
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Oct 18 2017
    Somewhere, GA
    And I agree with you..It's an awesome car that you can get for a third of the cost when it was new with not that high of mileage. I'm just willing to bet that a lot of people on here did not pay the 55-65k, me being one of them.
    I see where you're coming from, I've never had to have two sets of tires. In fact that sounds really annoying and it reinforces why I hate cold weather, I'd live in Florida if I could lol. Even in mild winter weather here people try and drive on their summer tires and it turns out very badly. All seasons have worked great for me though.
    Mar 28 2016
    Yeah, I've read a lot of those reviews, which is why I don;t have them. For the best summer performance, I recommend the BFGoodrich's I mentioned in an earlier post. They are extremely close to a summer tire, while still being acceptable in the winter. My only issue with them was an odd wear pattern that both I and a buddy with a Jag had (same tires). We both wore out the front driver's side tire way faster than the rest. No alignment issue. Odd that on two different cars (Jaguar XF and Audi A6) both wore the same tire out quickly.
    Apr 26 2017
    GLS 450
    Nashville, TN
    I think it is the sidewall stiffness. The DWS06's went on/off my wheels with reasonable ease. With my AS3+'s- that poor little guy had to really work.
    Previous
    Oct 18 2006
    Audiville
    Quote Originally Posted by brs2c View Post
    yes, dws had a tendency to be soft but higher psi (41psi) cured that... now dws06 does away with that for me and I don't even have to run higher psi... great updated tire to address that little shortcoming, for me.
    Oct 18 2006
    Audiville
    I have no problems at all with the dws06, steering response is great but as mentioned above generally run 41 psi front and 38psi rear as per audi full load specs... great and comfortable no issues here... very happy
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    I always wonder the opposite question: Why can't you get decent summer tires with higher treadwear numbers -- more like A/S tires? I realize they will not be UHP tires due to the harder rubber compounds, but you'd think I could find tires I can run all year round in FL that won't wear out in 15-20k miles. If I want 50-60k mile tires, they pretty much have to be A/S tires.
    As an FYI, I have R-compound tires on light wheels I use for the track -- no need for UHP tires for daily driving.
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Mar 28 2016
    Quote Originally Posted by TEB View Post
    You answered you're own question. The harder compound is what makes them A/S. Summer tires are much softer, hence the shorter wear. There are some "all season" tires which are really just summer tires with a harder compound that will perform "almost" as well as summer tires, won't turn into hockey pucks when the temperature drops below 40 degrees, and will wear better than summer tires.
    Apr 05 2016
    Portland, OR
    As a man with 5 sets of wheels and tires currently, dedicated winters are WAY better than all seasons.
    With that said, I rarely see snow or very harsh conditions so I'm switching to all seasons during the winter.
    I have 20k and counting on my Conti ExtremeContact DW's. I have 100+ drag passes on them and have cut some killer 60's.
    Can't ask much more for a summer tire.
    Geoff
    Aug 04 2017
    While we are on topic, "performance winter tires" such as the SottoZeros are garbage as well.
    Sep 19 2010
    Quote Originally Posted by whiped View Post
    LOL, I'm asking for more. Since I have dedicated track tires, I want tires for daily use in Florida that will last a long time. The DW's have UTQG=340, while the DSW 06 have a UTQC=560. I just want Continental to make a tire with the same tread pattern as the Extremecontact Sport using the DSW 06 rubber compound. I'm guessing that due to the larger blocks of tread, my fictional tire should handle slightly better in summer than the DSW 06, and not give up any life faster.
    My wife's MDX has DSW 06's -- which have been great tires. I just want something that looks sportier for my S4.
    Mar 28 2016
    https://www.bfgoodrichtires.com/tire...&zipCode=12570
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    All seasons are fine for most winter driving when they are new or nearly new. As soon as they drop below 50% tread, it's another story. So I run into the problem of having to replace a full set of A/S in December, when they still have 4/32" tread left.
    2012 S4
