Results 1 to 4 of 4
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    B6/7 S4 Door Blades OEM
    These are OEM door blades from an S4. The 2 front blades need a bit of work. 2 of the clip panels on the back side were screwed into the backing by the previous owner. In a couple spots they went through the front side with the screws. So there are small holes. One of the rear blades also has a gouge in it.
    Because of these issues these are being sold at a cheaper price knowing that they will need some body work to get them to fit properly and prep them for paint. 3 are grey and 1 is navy blue. Again, they will need body work.
    Looking for $150 shipped.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Mar 15 2010
    Bothell
    Bump for new price
    Mar 15 2010
    Bothell
    Bump
    Aug 22 2016
    new york
    still have these?
