Results 1 to 9 of 9
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    B6/7 S4 Door Blades OEM
    These are OEM door blades from an S4. The 2 front blades need a bit of work. 2 of the clip panels on the back side were screwed into the backing by the previous owner. In a couple spots they went through the front side with the screws. So there are small holes. One of the rear blades also has a gouge in it.
    Because of these issues these are being sold at a cheaper price knowing that they will need some body work to get them to fit properly and prep them for paint. 3 are grey and 1 is navy blue. Again, they will need body work.
    Looking for $150 shipped.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Mar 15 2010
    Bothell
    Bump. New price
    Mar 15 2010
    Bothell
    Bump
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Are these rusting at all?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Mar 15 2010
    Bothell
    Looks like there is a little rust on the two front ones from the pics I have shown.
    Junior Member Two Rings kirchh's Avatar
    May 15 2017
    Colorado
    still available
    Sent from my SM-G950U using Audizine mobile app
    - Kirchh
    Mar 15 2010
    Bothell
    Yep
    Junior Member Two Rings errol's Avatar
    May 24 2008
    '21 tiguan, '19 trd tacoma, '09 lr3, '07 element, '99 b5 a4 1.8t avant
    huntington station NY
    Quote Originally Posted by evo_ski View Post
    Yep
    PM sent. paypal ready.
    -Errol
    nerdin' it up on the Vortex since '01
    currently: '21 tiguan, '19 trd tacoma, '99 b5 a4 1.8t avant, '09 lr3, '07 element,
    May 24 2008
    Quote Originally Posted by errol View Post
    -Errol
    aaand Paypal sent. thank you sir. can't wait to get cracking on them
    -Errol
