Results 1 to 8 of 8
    Apr 21 2018
    Reston
    Downpipes, to cat or not???
    Hi all, new member/owner here, '13 S6. Anyway I just picked this sled up a week ago, and am already planning upgrades. Im looking at a stage 2 ecu tune and downpipes, question is should I go with or without cats? Whats the power difference between the 2 and can the CEL be coded away in the tune? Car is daily driven with the occasional trip to the drag strip, and at least for the meantime will retain the stock cat back exhaust system. Not too worried about noise either.
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    I ran no cats with my RS4 for a year. Stinks like hell, is terrible for this Earth we live on, and not sure if there's data that shows significant perf improvement over high performance cats. I finally went with the latter and couldn't have been happier.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Oct 31 2005
    Ashburn
    I think every car I have owned at some point was catless. I grew up around hit he drag strip so many folks were catless for the fact of exhaust sound and performance with race gas.
    Also race gas is bad for cats.
    - Instagram: @Sinister_rs5-
    Apr 21 2018
    Reston
    Didn't even think about the race gas angle, thats something I was definitely wanting to try out. So AMS or the Russian eBay pipes? Still concerned about emissions though here in NoVa...
    Jan 22 2017
    New York
    Leaded race gas is bad for cats...and your O2 sensors for that matter.
    Unleaded race gas is fine for either.
    I would go with catted downpipes if you are concerned about emissions.
    Established Member Two Rings drivenagain's Avatar
    Sep 05 2016
    MD
    Quote Originally Posted by low-profile View Post
    ^^This^^
    2013 Q5 3.0T | 57mm | 194mm | EPL DP Tune | Injen Intake
    2009 Aprilia Dorsoduro | TI Fuel Exhaust
    Mar 26 2010
    US
    The AMS catted down pipes will work with stock tune, Apr tune or Epl tune.
    The Apr down pipes work best with the Apr tune, but not with stock tune or Epl tune (in which case J extensions on the O2 sensor would be needed).
    Feb 03 2018
    Castle Rock, CO
    Who cars about leaded race gas being bad for cats.......Try running some through injectors. That will end well.
    Modern high flow cats are excellent and there really isn't a reason to not go the cat'd route. A few passes down the track are not a reason to go cat-less.
    Personally, the AMS or Russian made pipes with the GESI UHO cats is the way to go. I have seen plenty of dyno tests on other forums, not Audi forums, to know there is no HP/TQ to be had going cat-less vs a high flow cat.
