Results 1 to 4 of 4
    Apr 21 2018
    Reston
    NoVa emissions requirements
    Just picked up a '13 S6 and already have the itch to mod it. Would like to install a stage 2 tune and downpipes, question is should I go catted or not??? I actually just moved here from MD and know nothing of the emissions testing requirements for VA. Im in Reston if it makes a difference.
    Veteran Member Three Rings Fast4DR S6's Avatar
    Aug 28 2013
    MD/DC/VA
    Give the folks @ NGP Lorton a call when it comes to passing VA emissions. If you still lived in MD, you could get away with almost anything!
    2012 Golf R APR In-House Build - [U]European Car Magazine (July 2014 Feature Story)- SOLD
    2013 S6 APR/NGP Project RS6 Proto-type for all Stage 3 RS6/7 Turbos - Sold
    2019 Corvette ZR1 ZTK
    2021 Dodge Durango SRT HC
    2021 RS6 Unicorn Audi Exclusive Matte Paint
    Established Member Two Rings Tidi0x's Avatar
    Nov 21 2017
    Ashburn, Va
    In Virginia for most modern cars they need to pass visual for emissions. E.g. either or they can "see a cat" sometimes this is not possible because of how tight the spaces are in the engine bay, and the other part is not having a CEL or showing that the emissions system is still looking for readyness via obd2. What it really comes down to is if you are positive that you can eliminate the CEL with your downpipes, and that is typically done by using a O2 sensor spacer.
    Personally if I am throwing money at chancing not passing emissions I would just get HFC's and call it a day. On my old cars they have typically shown no power reduction, they really just add heat more than anything, which can reflect in higher egt's but hopefully the flow will out weight that.
    13' B8.5 | APR DP | Bilstein PSS10 | 034 Engine Mounts | ECS Exhaust | ECS Carbon kit | MercRacing cooler | BBS CI-R | Avanti Hybris
    Nov 17 2017
    VA
    It all depends on the person doing the inspection. Sometimes they are really anal and try to make a fast buck on the uninformed customer.
