Results 1 to 11 of 11
    Junior Member Two Rings
    Sep 26 2015
    Richmond/VA
    Multi Function steering wheel issues
    I need some help. I just had the following issue come up with the car and I think I may need to get a new Clock Spring? or is it something else.
    2010 Audi S4 72072 miles
    I had the car detailed is the only new thing I had done.
    First noticed the volume button did not work, and the then the mode button. Used the Carista OBD2 and showed an error. I cleared it shut the car off and waited for a bit and turned it back on. Everything worked at that point the next morning I come out and notice again, Vol, Mode and Flappy paddles not longer work. And I get the lights on the dash and when I pull out the VagCom this is what I get.
    Tuesday,01,May,2018,09:32:51:56175
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 18.2.0.3 (x64)
    Data version: 20180212 DS287.0
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 22 36 3C 42 46 47 52
    53 55 56 5F 62 6C 72
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: Cannot be reached 1100
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Cannot be reached 1100
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
    Component: 3.0T SIMOS84 H02 0003
    Revision: --H02---
    Coding: 0104000A240F0128
    Shop #: WSC 09417 444 85746
    ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
    ROD: EV_ECM30TFS0218K0907551D.rod
    VCID: 326B6F5E65F40ED4DE-8066
    3 Faults Found:
    6201 - Function Restriction due to Faults in Other Modules
    U1113 00 [047] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 20:10:26
    6082 - Steering Column Control Module
    U0212 00 [047] - No Communications
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 20:09:45
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 80 °C
    Intake air temperature: 48 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 12.390 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 1568 /min
    T_AST_ENVD: 0.00 s
    Gear: 0
    Engine: operating status: IS
    Battery voltage: 11.070313 V
    Vehicle speed: actual: 0 km/h
    6078 - No Communications with Steering Angle Sender (G85)
    U0126 00 [047] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 20:09:44
    Engine speed: actual: 1376 /min
    T_AST_ENVD: 0.00 s
    Gear: 0
    Readiness: 1110 0001
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 8K1 927 156 C HW: 0B5 927 156 E
    Component: 0B5 30TFSINAR H03 0002
    Revision: --H03--- Serial number: 0000000222
    Coding: 000001
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMDL501 A02044
    ROD: EV_TCMDL501.rod
    VCID: 35615442949A19ECFB-8060
    2 Faults Found:
    8007 - No Communications with Steering Angle Sender (G85)
    U0126 00 [047] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 20:09:44
    Engine speed: 0 /min
    Transmission input speed: 0 /min
    Transmission output speed: 0 /min
    Engine torque: -12 Nm
    Transmission fluid temperature: 40 °C
    Accelerator position: 0.0 %
    Clutch status: Beide Kupplungen offen
    8015 - Steering Column Control Module
    U0212 00 [175] - No Communications
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 20:09:44
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
    Component: ESP8 quattro H04 0010
    Revision: -------- Serial number: --------------
    Coding: 292D1A
    VCID: 7AFB877EF504369456-802E
    3 Faults Found:
    03110 - Active Steering Control Module (J792)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:41
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x0029
    Hex Value: 0x1698
    Hex Value: 0x00FF
    01324 - Control Module for All Wheel Drive (J492)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:41
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x0028
    Hex Value: 0x5098
    Hex Value: 0x00FF
    00778 - Steering Angle Sensor (G85)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:41
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x001C
    Hex Value: 0x7A98
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
    Component: BCM2 1.1 H02 0327
    Revision: 00002001
    Coding: 0D0100
    VCID: 78FF9D76CB08248420-802C
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 0209000100262011
    No fault code found.
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0171
    Revision: C1000000 Serial number: 01080220100823
    Coding: 66102000
    VCID: 000FF59693D86C4418-8054
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H25 0380
    Revision: 10025001 Serial number: 00000000582531
    Coding: 26001091063CAF313F00080300003D0D0F9CD2480201016100 0000
    VCID: 3C774166BFB0C8A404-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 270110 H06 0070
    Serial number: SWF10010270199
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10772583
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Serial number: 00000000000202101936
    Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
    Component: HOMELINK H01 0010
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:00
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
    Part No SW: 8K0 919 475 Q HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0070
    Revision: 11001001 Serial number: 51241004305540
    Coding: 20010D
    VCID: 479D2E8AF6769B7C99-8012
    Address 14: Susp. Elect. (J250) Labels: None
    Part No SW: 8R0 907 364 B HW: 8K0 907 364
    Component: DAEMPFUNGS-SG H09 0053
    Revision: 00000000 Serial number: 06021002110001
    Coding: 050181
    VCID: 39795872B082FD8C1F-806C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:45
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000001
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003EGD05HMW-
    Coding: 303837354230303030304A55304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID: 428B3F9ED554BE544E-8016
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
    Component: BF-Gewichtss. H01 0030
    Serial number: 5810000R0000005YBA
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME4F2213178
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME5006162E8
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME5E4E2536U
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME7C4C4718X
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME244E5302X
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME054E0614Y
    1 Fault Found:
    12658176 - No Communications with Steering Angle Sender (G85)
    U0126 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 19:55:36
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 Q HW: 8K0 920 980 Q
    Component: KOMBIINSTR. H05 0255
    Revision: 00300000 Serial number: CJ233382A
    Coding: 8B170900B300D705020000
    VCID: 408F3596D358AC4458-8014
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0105
    Revision: FB900055 Serial number: 5500F1013080D0
    Coding: 00C303
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H07 0170
    Serial number: 1000506B260110
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:51
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 12.00 V
    Count: 6
    Bin. Bits: 10011
    Time: 25.40 s
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:56
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 12.00 V
    Count: 6
    Bin. Bits: 10011
    Time: 25.40 s
    Address 1B: Active Steering (J792) Labels: None
    Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
    Component: DYNAMIKLENK. H06 0570
    Revision: 50001005 Serial number: --------------
    Coding: 8C0000
    Shop #: WSC 06324 000 00000
    VCID: 306F655663F83CC4A8-8064
    2 Faults Found:
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:32
    Freeze Frame:
    Count: 41
    Count: 1
    Hex Value: 0x0277
    Hex Value: 0x0B12
    Hex Value: 0xFAFF
    Hex Value: 0xF8FF
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.05.01
    Time: 09:25:15
    Freeze Frame:
    Count: 91
    Count: 1
    Hex Value: 0x0087
    Hex Value: 0x1A12
    Hex Value: 0xFAFF
    Hex Value: 0xF5FF
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 HW: 8K0 907 163
    Component: 4 Wheel Drive H09 0004
    Serial number: 000701100001039
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 6DD1BC22BC4A912CC3-8038
    2 Faults Found:
    0243 - Steering Column Control Module
    U0212 00 [137] - No Communications
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 19:20:10
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
    U1017 00 [137] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 21
    Reset counter: 8
    Mileage: 115994 km
    Date: 2018.04.30
    Time: 19:20:11
    Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0074
    Revision: AA000000 Serial number: 00001010070528
    Coding: 00581B00000000000000
    VCID: 3B75427ABABECF9C0D-806E
    Address 3C: Lane Change Labels: None
    Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
    Component: J0769_SWA_MasterH01 0030
    Revision: 00H01000 Serial number: 6PZ 009 014-82
    Coding: 0000001
    VCID: 3C7741667FB0C8A404-8068
    Subsystem 1 - Part No: 8K0 907 568 H
    Component: J0770_SWA_Slave_H01 0030
    Subsystem 2 - Serial number: 6PZ 009 014-92
    Subsystem 3 - Serial number: 5F03.02.1000H010003C320542ÿ
    Subsystem 4 - Serial number: 320542ÿ
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:56:15
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
    Component: TSG FA H11 0306
    Revision: Serial number: 0000010050331
    Coding: 011C13204E00410001
    VCID: 45812482CC7A896C6B-8010
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0126562193
    Coding: 01060E3A007A448500B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0050
    Serial number: 00000000000000217405
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
    Component: J245 PS037 H06 0041
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:30
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
    Component: DSP Prem H10 0190
    Revision: 00010001 Serial number: 34882001258201
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
    Component: TSG BF H11 0306
    Revision: Serial number: 0000010060381
    VCID: 44873986C740B0647C-8010
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000429894
    Shop #: WSC 00000 000 00000
    VCID: 3467694697E000E4CC-8060
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:33
    Freeze Frame:
    Voltage: 12.20 V
    Count: 80
    Speed: 0.0 km/h
    Hex Value: 0x0270
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000005
    VCID: 3467694657E000E4CC-8060
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 082 A HW: 4F0 035 082
    Component: Radio U SIRIU H45 0021
    Revision: AB001007 Serial number: 335BV0A7551195
    Coding: 020000010000000001
    VCID: 1D31ACE2046AA1AC13-8048
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
    Component: H-BN-NA H47 0042
    Revision: -------- Serial number: 490BU0A7546611
    Coding: 010200000206A1EF55000B0E000000030000
    VCID: 377D5E4A8696EBFCE9-8062
    Subsystem 1 - Part No: 8R0 060 884 F
    Component: NAR 2009/2010 5304
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Serial number: 9356BZ0A1189717
    Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
    Component: E0380 Bedient H08 0100
    Serial number: 00000000459126
    Subsystem 4 - Part No: 8R0 906 961 A
    Component: CD-Database 1293
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000102841186
    Coding: 010C13204000210001
    VCID: 428B3F9EDD54BE544E-8016
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H03--- Serial number: 525PA8-J0190CG
    Coding: 1001006
    VCID: 387F5D764B88E484E0-806C
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:28
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 6
    Reset counter: 8
    Mileage: 115994 km
    Time Indication: 0
    Date: 2018.04.30
    Time: 19:55:28
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000102841189
    End-------------------------(Elapsed Time: 04:11)--------------------------
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    This might sound like a dumb question, but since your car is 8 model years old, how old is the battery? You can get some unusual VCDS faults when you have a battery on its way out. But aside from that, it could be a clockspring or perhaps a connector issue in the column. Ever have the steering wheel off on this car or does it have any accident history to the front end/steering? Hmmm, just noticed that you had the car detailed. I wonder if whoever did it used any sort of sprays (e.g., silicone or other) near the steering wheel/column juncture, that may have gotten into places it shouldn't be.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Sep 26 2015
    Richmond/VA
    The battery is only 3 years old,as part of buying the car I had them add a new battery to it, so I am thinking it is not that. The Steering wheel was pulled off last night (pulled the negative lead from battery) I checked the connectors and looked at everything that is there. I plugged it all in and reconnected the battery lead. I am hoping that he didnt spray anything that would cause this but everything worked fine prior to and within 24hrs nothing works(hornvol and such) I cleared the errors but they came right back. And negative to the accident history.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Judging from your comments, issue just occurred after you pulled connections and used a spray, either all the connections where not properly reconnected or spray has caused issues.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    What kind of respectable detailer sprays onto the wheels or buttons over a rag then wipe tho.
    If he's good he wouldnt do that and would be using button safe stuff.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Jun 15 2013
    CA
    If all fuses are ok and turn signal, wipers work ok, you need clock spring just like you mentioned.
    Sep 26 2015
    Richmond/VA
    So I found out the turn signal, wipers do not work either. I ordered the clockspring last night but now I think I should order the stalks. The detailer is someone I used this one time, safe to say not happening again. I don't understand what could have caused this as the only issue I've had has been the Sirius radio will update frequently and I lose all my presets.
    Sep 26 2015
    Richmond/VA
    I question the respectable part. Something said don't let others clean your car cause they don't care enough. I should have bit the bullet and done it myself.
    Sep 26 2015
    Richmond/VA
    So I replaced the Clock Spring as well as the battery. But I tried to get into the Steering Module using the Vag Com but it says it cannot communicate with the module... I am still getting issue with my car and I am stressed out with this. Any clue how to get into this module to re-calibrate the steering angle?
    Jun 01 2018
    Alaska
    Any luck?? I’m having the same dtcs in a 2006 s4
    Jun 15 2013
    CA
    I am afraid that you need new steering column control module.
