Thread: Injector parts
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Injector parts
    So I’m in need of a part number or a cheap fix here guys. I have some newer model injectors going into older model year car and I’ve busted one of these little “crown” looking pieces. This pic below.
    Anyone who’s done an injector swap and has originals sitting around I’m ok w a used item. Just trying to push our platform a bit w a bit larger OEM injector. This part number was delivered direct from rev limit tuning in Greece.
    Apr 05 2016
    Portland, OR
    06E906189F is the part number.
    What are you looking to do?
    I believe the S3/Golf R injectors flow slightly more than the stock S4 injectors. (1200cc vs 1000)
    No one has confirmed it yet though.
    Geoff
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by whiped View Post
    Thanks a million. These injectors are used quite a lot in Poland/Greece in 2.0T fsi cars. These are said to correct the black exhaust issues and are to flow higher then the S3 and Rs4 injectors. From the info I have these flow 16% more then the S3 units many use in our platform. And yes not confirmed so at this point yes confirming this for others is the plan.
    Feb 10 2012
    parts
    Napanee, ON
    Part number worked and germanoem.ca was able to hook me up w the parts.
    Thanks whiped
    Apr 05 2016
    Portland, OR
    No problem.
    Let us know how it goes.
    Geoff
