Results 1 to 4 of 4
    Established Member Two Rings sicem13's Avatar
    May 10 2011
    San Antonio, TX
    Spacers on 18x8.5 et29 stock S5 wheels(?)
    Hey all,
    I cannot find an answer, probably because the wheels that came on my wife's 2013 S5 are the lamest wheels Audi has ever produced, but she likes them, so they must stay! That being said, I'd like to add spacers to make them sit flush with the fenders. The wheels I'm talking about are attached.
    They are the "five parallel spoke s-design wheels". Size is 18x8.5, et29.
    My question is: what spacers should I run to make them flush? Don't tell me 29mm. I'm just asking if anyone has kept these stock 18" wheels and put spacers on them to achieve a flush (or as close to flush as possible) look.
    It looks to me like 20mm front/25mm rear might do the trick after measuring, but wanted to see if anyone else had firm(er) data.
    Since every other question about this type of thing is discussing the 19" peelers or rotors, I had to start a new thread.
    Thanks in advance!
    2017 S6 Misano Red Pearl Sport - 15mm spacers / black badges / Roc Euro intakes / Suitcase muffler delete / VAGCOM / More to come!
    2013 S5 Glacier White Prestige DSG Coupe - EPL Stage 2 / EPL TCU / CTS intake / 4" tips w/ muffler delete / WRD+Swift Coilovers / RS grille / 20-25mm H&R Trak+ spacers / VAGCOM
    2013 Q5 Brilliant Black 3.0T S-Line - EPL Stage 1 / SQ5 diffuser / custom quad exhaust / VAGCOM
    Prior Audis: B8 A4 APR Stage 2, B8 S5 JHM tune
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    You are correct. 20 front, 25 rear is what got mine flush back when I was using those same wheels.
    Keep in mind my car is lowered about an inch also.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Jul 20 2011
    C8 Z06 Soon.
    Raleigh, NC
    Spacers aren’t too expensive. Check out the options at ECS Tuning. You can buy a few different sizes, install the ones you think will work first return the ones you didnt break the seal on. Nothing sucks more than ordering the size you thought would work only to find out you needed the next size up or down and now have to wait another week for shipping. I also found that I needed different sizes between fronts and rears.
    Harry P
    IE 80mm Throttle Body kit, IE TB and Crackle Tune, Jokerz Perfromance full S/C Port, APR 57mm SC Pulley, JHM 187mm OD Pulley, APR CPSv1 and Pierburg CWA 100-3, AWE Touring, GESi downstream cats, JHM Short Shifter, Southbound Stage 3 Clutch (600 tq), ECS Stage II Big Brake Kit, USP Metal Slave and SS Clutch Lines, Vorsteiner VFF-103 w/ H&R 5mm spacers.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Something to consider when running spacers: Clicky click®
