Results 1 to 4 of 4
    Aug 12 2015
    Minneapolis MN
    warped / damaged rim?
    It was a rough winter here in Minnesota and was playing keep away from all of the pot holes. Hit a few along the away unfortunately. Just had my summer tires put back on. Is there a sure fire way to determine if a rim has been damaged? I do have a very slight vibration but could be just me being sensitive to the winter tire to summer tire switch. Is taking it to the shop to check the best solution?
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Going to a shop and having them balance the wheels is the best way to know.
    Sent from my Pixel XL using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    May 20 2010
    If it's put on a balancing machine (with or without a wheel), it will wobble or visibly there will be something to see. Mounting the tire will exaggerate this, making it easier to see.
    If you put the summers on the same wheels, the shop should have noticed or put so many weights it's crazy. Now, does that shop road force balance? If not, take to one that does. That'll be the most sure-fire way of ensuring it doesn't vibrate at speed.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Feb 14 2018
    2005 Yamaha R1
    Minneapolis
    Quote Originally Posted by db12 View Post
    I actually bent a wheel this winter in Minneapolis. the next day i took the car into Imola Motorsports, they took a look at it and proved my assumption to be correct. they threw it on a balancer and then aligned it again. thankfully nothing was broken.
