    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Vibrations under load
    I have been fighting this on a 2006 A4 2.0T Cabrio FWD (CVT) for a week now, and are lost.
    Car has 150k miles.
    The car exhibits massive vibrations under load. NO vibrations off throttle/coasting or coasting in N.
    Vibrations at all speed.
    Frequency changes with driving speed (wheel revolutions) not engine RPM.
    Done:
    front right wheel bearing has a bit of play. Changed.
    found excessive engine movement. assumed snub mount. Replace with red poly snub (installed centered under dead weight of engine).
    still movement on passenger side, replace motor mount (stock mount).
    still movement. Particularly when going from P to R. Took video from under car, found that rear trans mount is bouncing up big time when shifting into R. Found that center bold of the mount (and a holder on the bottom?) is missing. Ghetto fixed by removing the mount, put nut on top and bolt with large washers from bottom. No more movement.
    Took car to shop for test drive. Then on hoist, mechanic commented when inspecting the drive shafts that they had NO axial play (but expected them to have some play to allow of up/down motion of wheels and to avoid to put pressure on the constant velocity joints and the transmission output shafts). He lifted up the engine (weight of suspension) and then shafts showed the expected play.
    a) on its own weight, are the drive shafts supposed to have some axial play?
    b) if not, what might CAUSE the drive shafts to bind.
    Any suggestions how to further troubleshoot?
    It is NOT known if drive shafts are original or if they have changed. But vibrations were NEVER that bad prior.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    May 20 2010
    How about your transmission and rear differential mounts? Those do go bad over time.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Feb 20 2010
    Brighton, MI
    I haven't found them to cause such 'hard' vibrations. They do created clonks and excessive engine movement.
    Unless the wear is causing the secondary issues (for example drive shaft binding?) that in turn causes the distinct speed/load dependent vibrations.
    05 Golf TDI
    Feb 24 2004
    Minneapolis
    I bought a Passatt with engine problems. Fixed that (bent valves and valve timing adjuster) then had a vibration like that. Luckily you can swap wheels/tires between my Audi and the Passat. Immediate relief. Bought new tires for the Passatt and put them on the same wheels: no vibration. As I understand it, if the tire carcass goes bad, a belt can slip around and make the tire un-ballanced.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Senior Member Two Rings Tyintegra's Avatar
    Sep 13 2010
    2013 A4, 2013 Golf R
    Bothell, WA
    Quote Originally Posted by vtraudt View Post
    Car has 150k miles.
    Done:
    These are the same symptoms I had on my B8.5 when it was in need of fuel injectors and a carbon cleaning.
