Results 1 to 10 of 10
    Oct 16 2014
    Part number for old driver side VC gasket?
    audi won’t sell the old VC gasket (they will happily sell the entire VC) so hoping to find someone else who still stocks / sells the old part.
    Anyone here have that part number?
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    I cut out the couple of spots to modify my valve cover to accept the later revision gasket. Last resort option if you want to also upgrade to the revised gasket.
    Oct 16 2014
    Quote Originally Posted by S4Bennett View Post
    Wait you modify the cover itself? (Or you mean the gasket?)
    If you’ve got pics I’d appreciate seeing
    May 29 2010
    I cut the cover.
    Veteran Member Three Rings blubusdrvr's Avatar
    Mar 02 2015
    1970 LT1 Corvette, 2017 A4, 2001 996TT
    Maryland, United States
    Oh, wow. First I've heard of someone doing that. I recently replaced mine but I modified the gasket. Not the perfect solution but I wasn't about to spend $$$ on a new valve cover.
    Oct 16 2014
    Quote Originally Posted by blubusdrvr View Post
    Pretty sure this is the pre-update gasket:
    https://m.ebay.com/itm/New-Febi-Valve-Cover-Gasket-079-103-483-R-/292402068676?_trksid=p2385738.m4383.l4275.c10&_mwB anner=1
    May 29 2010
    Oct 16 2014
    What tool did you use to cut it?
    I ordered the part by Febi I posted above (which says is for “pre-update VCs”) but I see from the pic on the website that the gasket fully encloses the last spark plug hole. Will confirm when I get the actual part.
    May 29 2010
    I reckon I started with a worn down Dremel cutting wheel and moved on to a 1/8” drill bit in the dremel. A small routing bit might be better but I didn’t have one.
    Oct 16 2014
    Ok- may try this if the gasket doesn’t actually fit
