Results 1 to 6 of 6
    Senior Member Three Rings sleepwalker_gsr's Avatar
    Jul 08 2010
    Your mom, tied up.....
    sacramento CA
    DV flutter/ Rasp from exhaust
    Hello all!
    I've got a 008 DV with the heavy spring that supports up to 30 PSI (im at 22-23) and i'm getting flutter really bad. Is this an issue? Will i lose power? I'm not getting a code yet. I've got a GT2871r and it even did it with my K04.
    Also ever since i installed the GT its become really raspy like a Honda. I REALLY don't like this sound but its only become an issue with the GT. Is this normal? What can i do to reduce this sound? I'm currently straight pipe with magnaflow resonators.
    2003 B6: GT2871R turbo, Snow Performance Water Meth, Motoza tune, FMIC, Straight pipe, ECS RA4 Stage2 Clutch, 034 fuel pump, 034 TIP, Bosch 550cc injectors, fuel rail, 008 DV, Carbonio intake, coilovers, S4 door blades, USP front bumper and painted lowers.
    Jul 08 2010
    sacramento CA
    from what ive read its due o the spring being to stiff. ill throw the green one in and see what that does for me and increase as needed..
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    You want to run the softest spring possible without loosing pressure. Drop down to the next softest spring and see if anything changes.
    Regarding the exhaust noise, your sig says straight pipe. Id start by adding a quality resonator and muffler.
    2019 SQ5 Prestige
    Established Member Two Rings marto7's Avatar
    May 06 2017
    Sofia
    I had the exact same issue with my Bailey DV26 before i connect it directly to the manifold.I am with K04-064 turbo on 1,5bar pressure.From then i dont have this problem.I dont know if my N249 is with problem but this fix my issue
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    The fluttering is compressor surge. If it's happening at full boost, you need a softer DV spring as mentioned.
    Jul 08 2010
    sacramento CA
    Quote Originally Posted by texasboy21 View Post
    any suggestions for the mufflers and resonators?
