Results 1 to 4 of 4
    Jan 17 2018
    Colorado, U.S.A
    Speedometer problem
    I've been having a problem with my 2004 audi a4 3.0. The abs and traction control lights turn on and caused thespeedometer to stop working. If i turn the car off once the light goes off and everything works fine, up until the car is off again in which case the lights go back on. Tends to happen more if the car is colder. If i drive the car with the lights on, when i shift gears the transmission seems to have trouble shifting. Anyone else have this problem? Is it an abs speed sensor, transmission sensor, speed module? Thanks!
    Jun 08 2017
    london
    Did you check the battery ground? Did you scan for codes? Sounds electrical...
    Jun 30 2008
    Erie, Pennsylvania
    You need to scan for codes. Most probably there will be a code in the Engine and/or Transmission computer for no vehicle speed signal (probably "P0501 - Vehicle Speed Sensor A, Range/Performance" or similar). On your A4, the VSS is handled by the ABS module, so checking for ABS codes will likely get you closer to the actual fault. Perhaps a faulty wheel speed sensor. Once you make the ABS module happy, and clear all your codes, everybody else should fall in line. The automatic transmission does depend on accurate Vehicle speed signal for tuning the shifts. Your symptoms all point back to a problem with the ABS/Vehicle Speed.
    Do note that just because there is a code for a wheel speed sensor does not necessarily mean the sensor itself is faulty. The sensor reads a "tone ring" (aka "reluctor ring") that is bonded to the CV joint. Rust buildup in the notches or cracks in the metal tone ring can cause faulty readings. Also, rust/debris buildup on the end of the sensor can cause issues as well. Because the sensor is reading properly some of the time, I would be more diligent about inspecting the tone ring and associated debris before purchasing any parts. It is possible to check the resistance of a wheel speed sensor with an ohmmeter. A further check is to actually see it's output. This can be done with an voltmeter in AC milivolts mode. An even better test is to connect it to an Oscilloscope (or a digital scope function of a scan tool, etc) and look at the quality of the waveform that the sensor is producing at various wheel speeds. It's not generally necessary to get quite that deep with the diagnostics unless the issue is proving difficult to rectify. Good Luck.
    Jan 17 2018
    Colorado, U.S.A
    Thanks! Yeah the code that i recieved was P0501.. i'll be looking into the resistance of the speed sensors here shortly to see what the problem is.. much appreciated!
