Results 1 to 7 of 7
    Oct 02 2016
    Bubble in tire - replacement
    Saw I had a bubble in a tire (front pass). Went to the tire shop they said I could replace it because it was close enough to the tread on the new tires. The tread on the front drivers was about 7/32 to 8/32 while the new tire was 10/32.
    I just got my tire swapped out. Should I go back and get the shop to order 3 more and replace them all?
    Mar 20 2015
    McKinney,TX
    I would of replaced the two at the front and keep the one good 7/32 as a spare, just in case. That way it wont pull to one side.
    Then try to even them out over the next year by rotating, or not rotating, to wear out the new ones at a faster rate
    I wouldn't throw away hundreds of dollars of tire life.
    Senior Member Three Rings BlackJon's Avatar
    Mar 07 2018
    If your not First, your Last- Ricky Bobby😏
    Philadelphia, PA
    Quote Originally Posted by EIAlfonso View Post
    I agree with ElAlfonso on this.. that's what I would do
    Drive it like you stole it 😎
    Established Member Two Rings nowakm99's Avatar
    Jan 21 2018
    2016 Audi S4, 2012 Cayman S, 2025 Integra Type S
    Toronto, Canada
    I'm going to take a wild guess here: Are you on Pirellis?
    2016 S4: IE Stage I, IE CAI, AWE Touring Exhaust, CR-15, H&R Rear Sway bar w/ Moogs end-links, 034 Motorsport transmission mounts, Vorsteiner V-FF 103s in Machined Titanium
    Oct 02 2016
    Quote Originally Posted by nowakm99 View Post
    Actually I was on Michellin all season tires
    Deactivated Four Rings
    Jun 23 2011
    Tire Rack can shave tires down to match and they have a warehouse in CT.
    Registered User Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    You are perfectly fine, the only thing to watch for (off the top my head) is the average thread on front vs rear should be max 2mm. May differ slightly along models, if you want send me your VIN and I can check the details. Still if you don’t care it would be good to replace both on the same axle when you have to replace one.
