Results 1 to 9 of 9
    Deactivated Two Rings
    Feb 11 2017
    London
    2014 B8.5 S4 Rattling when slowing down to a stop
    As title says, recently noticed that when I have the window down and slowing down to a stop I hear rattling which gets louder towards complete stop.
    The car does not shudder and drives fine, and don't have the technical know how to investigate under the car.
    I did get the car installed with an X-pipe last year and no issues so far and does not rattle when at full throttle.
    Anywhere specifically where I should be checking for loose bolts or metal shield?
    Should I bring this to a shop to look into and fix?
    Thanks in advance.
    Jul 02 2017
    2012 VW GTI, 2015 Nissan GT-R Premium
    Smyrna, DE
    Sounds like it might be rattling from a resonator or a heat shield. While parked, try holding the throttle at various rpms, e.g., 1k, 1.5k, 2k, etc., and see if you can reproduce it. If you can, it’s probably rattle somewhere along the exhaust.
    If yes, then it can be done while on a lift and the exact source should be able to be located.
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    flex pipes most likely
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Feb 11 2017
    London
    Quote Originally Posted by maty360414 View Post
    Thanks, is this something I should bring to Audi for or a small shop to fix?
    Is this a side effect of going X-pipe? I don't think I heard this rattle before.
    I tested the throttle and its exactly rattling at 1k while dropping.
    Going up in throttle doesn't make any rattle, but the side affect is a smile to my face :)
    Jul 02 2017
    Smyrna, DE
    Quote Originally Posted by 1ronin View Post
    Cool. It is most likely completely benign. However, you don’t have much to lose by bringing it to a shop to see if it is something that can be corrected by a quick adjustment. Alternatively, if it is pretty subtle, I would just occasionally monitor for any worsening of the rattle.
    Feb 11 2017
    London
    Quote Originally Posted by SGR View Post
    Sounds good, I'll keep monitoring it for a bit while also looking for a shop nearby.
    I don't drive much as I mostly work from home, but today I went into the office and was in stop and go traffic.
    Every time the revs dropped around 1k, the rattle would show up.
    Jul 02 2017
    Smyrna, DE
    Sounds good! Enjoy the exhaust!
    Veteran Member Three Rings AFR1485's Avatar
    Nov 24 2015
    Fiat 500
    It’s the downpipes. The OEM part is know to rattle. You can go to Audi and pickup and oem replacement or get a set pair of aftermarket pipes.
    Feb 11 2017
    London
    Quote Originally Posted by AFR1485 View Post
    Thanks, yes the sound is coming more towards the front rather than the back.
    Is this something I should be concerned about? (Leaks, potential expensive repairs down the road)
    How much do DP's go for, and will going aftermarket revoke my warranty? (I'm CPO with warranty til 2022).
