Results 1 to 4 of 4
    Established Member Two Rings Longwolf's Avatar
    Oct 27 2005
    Gainesville, FL
    Is there a simple to follow maintenance schedule for our cars?
    The Audi published schedule is just a disaster of confusing and conflicting service intervals. Has anyone seen a nice and straightforward schedule for our cars?
    It makes my brain hurt to see this mess of a document:
    https://www.audiusa.com/content/dam/...e_9-7-2017.pdf
    Christian Longwolf, Gainesville, FL
    '13 Audi S5: the daily hammer
    '23 Audi allroad: the kid hauler
    '18 Audi Q5: the grocery-getter
    '07 Honda S2K: the weekend toy
    '87 Porsche 951: the other weekend toy
    '06 A4 3.2 Avant: the airport car
    '87 Mercedes 420SEL: the beater & eventual project car
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    At first glance it's a little confusing, but once you go throught it a couple of times it's cake. Print it out and use a hightlighter.
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Senior Member Two Rings AWEs5's Avatar
    Jul 18 2017
    Gardena CA
    Quote Originally Posted by mcbuck View Post
    I read this thing all the time when I am bored at work. To sum it up...you change your oil every 10K miles and your spark plugs every 40K. The 55K is a major service and it will likely be the most expensive one. I believe you need to change the Ribbed V-belt. I've always wonder if this is another name for the timing belt because that diagram does not say "timing belt" anywhere. If you drive your car hard then I suggest an oil change every 5K miles. Always check engine oil level since it tends to burn oil. I always top off around 1-2K miles. Other than that, check and replace transmission oil every so often like you would normally do. The thermostat on these cars tend to go bad so I would watch out for symptoms. My car overheated due to thermostat failure. It happened literally 5 days after getting back my car from its 55K service and I did not experience any symptoms prior to the incident. I was lucky that I was on local streets so when the car displayed the message about "temperature" I was able to pull over right away and wait for a tow. The fans were going crazy.
    There is a very good thread on AZ about carbon build up for these cars as well. But the sticky is for FSI engines. I would assume it applies to TFSI as well. So maybe do a carbon cleaning at least once every 40K or so. That service will cost at least $700-$1K. I've own my 2013 S5 since July 2017 and have put around 9K miles on her and these are things I've learned so far. Great car and I love her.
    2013 Audi S5 Premium Plus | H&R springs | AWE S-Flo CF intake | AWE Touring Exhaust 102mm Diamond Tips | AWE non-resonated downpipes |
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Quote Originally Posted by AWEs5 View Post
    I believe carbon buildup is just a side effect of pretty much any car using direct injection. I get the impression that the buildup occurs at a slower rate on TFSI cars compared to FSI though.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
