Results 1 to 9 of 9
    Established Member Two Rings TooDamnFresh's Avatar
    Feb 05 2018
    Bay Area
    Low boost (limp mode) when car is driven more then 30 minutes or when its hot
    Hi guys,
    I've been searching but could not pinpoint a thread related.
    My S4 has been acting weird. After 20-30 minutes of driving my boost is stuck at 5.2-5.3 PSI. Like it is in limp mode. I checked for boost leaks. I couldn't find anything. Throttle body boot seems to be good.
    First thing in the morning, or driving when it's cold, it seems to be fine. Boosting around 17PSI.
    No codes. No cel. Car runs and drives fine as well. Just the boost cuts when it is hot.
    I am thinking anywhere from N75, Throttle body adaption?, or Heat soak from intercoolers?
    Current modes:
    Stage 1 - GIAC tune - oldschool chip with chip soldered into ECU.
    SSAC Twin 1 - With downpipes
    Any help or if anyone could point me in the right direction, that would great. Thanks in advance.
    Thanks
    Mike
    2001 Audi S4 - Nogaro / Alcantara - Weekend/Project
    2017 Toyota 4runner TRD PRO - Cement - Daily
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    You need to see what code is throwing it in limp mode. Anything else is just a guess. Scan your car.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Feb 05 2018
    Bay Area
    Quote Originally Posted by CELison View Post
    That's the thing. There are no codes. No DTC's. No CEL.
    Feb 05 2018
    Bay Area
    Anyone experience this? I am planning to start with N75 even though there are no codes, DTC, or CEL. Or is it pointless just throwing one on there?
    Mar 12 2015
    Almost strikes me as something getting flagged towards the end of a drive cycle. Can you pull up the readiness monitors on vag com while you're driving and see if there anything fails around the time it stops boosting normally?
    Feb 17 2011
    maybe egt's. what are you using to scan for codes?
    Feb 23 2010
    Emmaus Pa
    You have to use vcds, not a generic scanner. FYI
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Feb 05 2018
    Bay Area
    Fixed. Thanks everyone for your input. It was the N75
