Results 1 to 9 of 9
    Senior Member Three Rings WewannaB7's Avatar
    Dec 07 2014
    07 Porsche Carrera S Cabriolet, 12 M-Benz ML350
    New Jersey
    Wet rear seatbelt?... is it the sunroof drain?
    Wife sat in back passenger side yesterday, and she said the seat belt was wet. Is this because the sunroof drains are clogged?...I’m assuming it’s the rear drains? How do I get to these to clear them. Thanks in advance.
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Yep sunroof drains. I have yet to find a really good DIY on cleaning them. And it’s always the back right seatbelt 😕
    2008 A4 2.0TQ Ti - 6MT
    1991 MR2 Turbo - 5MT
    1997 Pathfinder 4x4 - 5MT
    ~Marc
    Dec 07 2014
    New Jersey
    Quote Originally Posted by QuattriumMT6 View Post
    Crap! :) ok, thx...guess I’ll be figuring this out myself. Lol.
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    Quote Originally Posted by WewannaB7 View Post
    It's actually pretty straight forward. I think I was able to google a thread between Audizine and other VW/Audi forums that had a decent pictures (may be broken by now). Buy some string trimmer line and go fishing!
    The fronts drain to the front door jams, the rears drain to rear wheel wells behind the liner. The hardest part is pulling back the headliner enough to check out if there's leaks at the rear of the sunroof drain overflow tank (right above the C pillar). While you're in there, I would add some self-fusing silicone tape up there so you know that tube isn't leaking. Mine was leaking even though it wasn't clogged.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    I had to do this a couple weeks ago. I took off the rear dome light and then the long piece of headliner trim across the top of the windshield. I also took off both rear ceiling handles.
    There are some good pictures here that show the headliner trim and C pillar that you'll need to take off
    https://www.audiworld.com/how-tos/a/...-buzzer-422192
    Once you take all of that off, you can wiggle the headliner down a little to access the sunroof drains but be careful because you don't wanna bend/crease the headliner.
    Not my picture but this is where mine was leaking. The drain tube wasn't attached to the drain plug/port on the sunroof.
    http://forums.pelicanparts.com/porsc...oof-drain.html
    Better pictures of the front and rear sunroof drains
    http://forums.quattroworld.com/a6/threads/816.phtml
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Dec 07 2014
    New Jersey
    Thanks guys! I will take a look this weekend to see what’s the cause.
    Jun 27 2011
    Mine was leaking a few weeks back, I peeled the wheel well cover off on both sides (had to remove the rear wheels, annoyingly). I just shoved a length of weed whacker line up the hose until it wouldn't go any farther. I don't think the drain was clogged though, I think the nipple was just stuck shut after however many years of draining rainwater and whatnot. When I squeezed it a couple ounces of water came out each side so I figure it was a good thing I caught it before the ceiling got too soaked.
    Just do that, and most likely you'll be fine. If it keeps leaking then consider ripping the interior apart.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 07 2014
    New Jersey
    Thanks...this is what I am going to do first. Saw some videos about this and hope this works. If not, it’s pulling liners time.
    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    Ditto on just burping the fitting in the rear wheel well. This worked for me.
    Kevin
    2015 A7
