Results 1 to 7 of 7
    Senior Member Two Rings niedzial1983's Avatar
    Jun 05 2016
    surrey, uk
    Window regulator driver side
    Any tips on replacing window regulator on dirver side ? Mine failed , i can hear the motor going but windows does not move uo or down...
    Sent from my SM-G950F using Tapatalk
    May 23 2016
    Edmond, OK
    Tip- Once you get it out, make sure to inspect the regulator. As at times, the regulator itself is intact but it is actually the plastic "bracket" that bolts the glass to the regulator's slider mechanism that breaks. At that point, an expensive-ish fix becomes a rather cheap fix :D
    There are proper how-to instructions on here and also on Youtube. It should be the same instructions for both driver and passenger side fronts.
    CURRENT- 11 BMW 535i M-sport- Shuenk N55+ Turbo/ Intake/ GPlus IC/ CP/ DP/ Valved Mufflers/ Custom MHD/ HelixOD/ Walbro450/ B58 Coils/ Brembo G12 F Brakes/ H&R Sport
    GONE BUT NOT FORGOTTEN- 07 A6 3.2- Morimoto 5500k/ Nokya 2500k/ DeAutoLED Rev, LP, Footwells/ Ziza Interior/ 10" Pioneer/ Audi Aluminum Pedals/ Stoptech X-Drilled & Sport Pads, ST X-C/Os, Hacked Airbox+ aFe, Resonator Delete
    Jun 19 2017
    ABQ NM
    Pretty much what 95blkmax says. I had found a troubleshooting guide somewhere, that helped me narrow it down to the Bracket. As I remember, if the window is forced up with the power motor, but not down, it is most likely the Tab. There are a right and a left. make sure you order the correct one.
    Mine - 07 S6 Stock
    Wife's 07 A8L 4.2
    May 23 2016
    Edmond, OK
    OH VERY IMPORTANT! This is the website you would source the plastic bracket from.
    http://regulatorfix.com/
    I hope it's as simple as replacing this by itself! If it is, I would recommend that since you have the regulator outside already, go ahead and clean the rails and pulleys with rags and then spray a thin coat of white lithium grease on it to keep it like new.
    Good luck!
    Jun 19 2017
    ABQ NM
    Quote Originally Posted by 95blkmax View Post
    Good luck!
    I second this, good product, fast shipping .
    Taking your car apart like this is a bit freaky, but take your time and it is not that bad.
    Mine - 07 S6 Stock
    Wife's 07 A8L 4.2
    Jun 05 2016
    surrey, uk
    Broken cable ...
    Jun 19 2017
    ABQ NM
    Yuck. more than the retainer clip.
    Mine - 07 S6 Stock
    Wife's 07 A8L 4.2
