I need some advice on whether I have all the required wiring to swap the cluster in my Australian S4 B5 (I live in Australia), My old cluster burnt out (the circuit board is toasted and cannot be plugged in at all) and needed replacing so I got a spare one from the US. Problem is i plug it in but can't access the cluster to recode it for my Australian Gauge faces (Km's, Degrees C, etc). The car has an Immo defeated ECU so its not an immobiliser issue as the car runs and it drives fine, the cluster shows revs, temps, speed etc but the scale is wrong for the speedometer as its scaled for the US face that shows Miles on it. I also cannot access the cluster to change the Odometer to match my old kms (183,xxx). I have already run a direct wire from my OBD2 Port (Pin 7) to my ECU (Pin 43) and it works because without it the ECU cannot be accessed at all. Are there any other wires I need to run to make it possible for me to access the cluster with VCDS or anything that I am missing or is it possible I just got unlucky and have a dud new cluster?
